Old 12-01-2006, 01:59 PM
bajarick bajarick is offline
Rep: 10 Posts: 3
tunnel hull deck replacement
Hello
I have an old 14ft tunnel hull that needs to have the transom and deck replaced. I am confident that I can fix the transom, but I have doubts about how to rejoin the deck to the hull. I dont want any leaks and the boat sits so low in the water the seam at the rear of the deck will be under water at times. My question is how to properly rejoin the deck to the hull so that there wont be any leaks?? Pics of the hull are attached.
Thanks
tunnel hull deck replacement-mvc-009s.jpg  tunnel hull deck replacement-mvc-010s.jpg  tunnel hull deck replacement-mvc-017s.jpg
Old 12-01-2006, 07:59 PM
tja tja is offline
Rep: 11 Posts: 125
Tja
If the deck it's self doesn't need replaced you might want think about cutting out the rear part of the motor well which will give you access to the center of the transom and the balance can be reached from under the deck. Not The easiest way to do it but will keep you from removing the deck. If you remove the entire deck it should be glassed tegeather at the seam. Good Luck. Tom.
Partial Ply Deck Replacement Technique darrenyorston Wooden Boat Building and Restoration 5 09-12-2006 12:43 PM
Mariner 40 deck and cabin replacement mariner 40 Materials 13 12-10-2005 05:17 AM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 06:20 PM
Suggestions on replacement deck (lightning sailboat) ldrumond Wooden Boat Building and Restoration 9 02-05-2005 12:39 AM
Deck replacement Busted Knuckle Materials 0 03-31-2004 04:02 AM
