| is tree sap on older gel-coat a big problem? would a good coating of sap on this boat devalue it any more than an afternoon's worth of elbow grease? How to clean a couple years of sap off the gel-coat without damage? sap will brittle after a while. Quote:
| Hot water, low pressure. Kärcher! The more solid parts: rug with turpentine, soon rinse with soap water. Regards Richard |
| apex....."Kärcher" ??? what does "Karcher" mean? |
| Use a heavy duty cleaner, like "Spray 9" or other. Mineral spirits or turps might spank it, though gasoline will probably wipe it right off. Of course get the area rinsed quickly after. |
| S -D Kärcher is the manufacturer of the most common pressurized, hot water units known on earth. |
| Good idea Richard, but I was thinking why not just sail it off... Prolonged exposure to water may well dissolve it.
| At the end, water will dissolve everything, you are right Fanie. And Paul: I did not say any sort of solvents and agents! Plain, real Turpentine, was my recommendation. |
| Karcher is great but don't let nozzle get too close to finish or it will cut like a knife.
__________________ Hoyt Lighting is very selective and will not strike crap. Wynand N http://www.genocidewatch.org/southafrica.html http://www.saabc.net/ |
| Yes, I know but it can't be said too often.
| maas aero Do you still have this for sale? |
| Turpentine dries slowly and is works well. There is a general adhesive remover by 3M that also works well
__________________ Gonzo |
| A blast with a co2 fire exstigisher and freeze it it will just about fall off !! |
| I have found achohol is the only thing that cuts our pine sap. Try it. |
| Pinholes in the gel coat problem. | Seb790 | Fiberglass and Composite Boat Building | 5 | 08-29-2009 05:57 PM |
| Gel coat | nrodes | Materials | 13 | 01-25-2009 11:54 AM |
| gel coat | alfiej44 | Fiberglass and Composite Boat Building | 10 | 09-05-2008 07:16 AM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 09:53 PM |
| Gel coat | jeremyb251 | Materials | 1 | 03-16-2006 01:40 AM |
