Old 10-25-2006, 02:59 PM
asianbandit asianbandit is offline
Rep: 10 Posts: 28
Transom replacement - Top of boat removeable??
Alright guys, Finally got the chance to look inside the transome..and guess what..it is totally rotten...alright no big deal i can deal with that...here is my question...
I have a 14' tri-hull glass boat. There is a lip/cover that goes around the hole edge of the boat. After closer examination it seems like i can unscrew the all of them around the boat and the whole top part of the boat will come right up and give me access to the transom. Is this a good idea to do? Or should I cut the transom, to get to the rotten wood. Here is a pic to kind of show you what i am talking about...
Old 10-25-2006, 05:55 PM
SamSam SamSam is online now
Rep: 502 Posts: 1,683
Yes, the cap is removable and it does make it a lot easier to work on the boat. You have to be carefull the shape of the hull doesn't change while you are working on it as all the new glasswork will lock that shape in and the cap might not fit back on, or the bottom shape might get twisted or lumpy and give a strange ride. I think you might as well count on gutting the hull and replacing everything anew. This has been done and discussed numerous times and using the 'search' feature will tell you everything you want to know. Here is another site that has an awful lot of people doing this sort of thing. 'Boat Restoration and Building' and 'Boat Topics and Questions' are the forums you want. You'll have to join to ask questions and 'search', but it's worth it. Sam
http://forums.iboats.com/
Old 10-26-2006, 09:37 AM
Rep: 10 Posts: 28
SAm SAM
Sam thanks for the link...i think this site will help me tremedously>>
Transom replacement isby Powerboats 3 09-27-2006 04:51 PM
20 ft bertram transom replacement el pescador Fiberglass and Composite Boat Building 2 08-24-2006 04:59 PM
Transom Replacement Foam vs Marine Ply MJB Materials 3 06-14-2006 03:52 PM
11' Inflatable - Transom Replacement chrismiele Wooden Boat Building and Restoration 0 06-08-2006 04:27 PM
transom repair/replacement? ldolbee Fiberglass and Composite Boat Building 5 01-13-2005 10:27 AM
