Closed Thread
  #31
Old 10-19-2010, 03:22 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Originally Posted by Astute Boats View Post
PAR/Paul...
I think that you need to take it a bit easy here, its not your forum...
You discounted my original post a incorrect, now you are changing your tune.
Your instant dismissal and continued singled mindedness is cause for the attitude.
So what if I don't post that often, don't expect me to kiss your ass because I don't plaster my opinions on here twice everyday. I'm a touch too busy "at the sharp end" to rack up 5k+ of posts... Hence, I'm not on here to looking to bolster my self esteem either, just helping out when I can.
If you like it better, I will not bother anymore - if you get so offended that someone has a tad more info to chip in.
My concern is that:
The method you prescribed is not risk free to the novice and therefore could bite someone in the backside.
I would NEVER stick any thing bigger than 4" square the way you suggested, but, I do operate at the top of the composite boatbuilding ladder and up here we push the quality onwards, techniques get pioneered, incorporated as Standards and handed on......
Shame on you and enjoy 'your' forum.
Check out my Powerplay thread on OSO Best Regards.
Slippery when wet.
www.cheetahcat.com
  #32
Old 10-19-2010, 03:24 PM
apex1
Originally Posted by dead_eye_dick View Post
Hi Astute Boats,
Thanks for your reply. I have never done this kind of a repair before and never worked with epoxy or polyester either, so please forgive me if the following question sounds stupid: Would pre-drilling the core of the plywood with 3 mm holes every 50 cm apart weaken the overall strength of the plywood. Your method of drilling these holes makes a lot of sense.
No, it does not make sense!
Donīt listen to these "experts".
Astute is a completely unknown quantity here.
GC is just a bigmouth
And War Whoop, well, every of his comments is just that. A war whoop...
Though he should know better, being a builder himself. But obviously he does not.
Go with PARīs advice, several hundred readers, members and customers did it with success!
No need to perforate the transom, thats nonsense. And believe me I did several transoms..............
Yes there are holes, two on each transom, 10in. diameter. Making sure there is no gap in the layup (and providing the exhaust pipe through hulls).
Regards
Richard
  #33
Old 10-19-2010, 03:40 PM
Rep: 84 Posts: 661
Regards
Richard
You should not give advice, remember by opening your mouth you have proved yourself to be a idiot.
Slippery when wet.
www.cheetahcat.com
  #34
Old 10-19-2010, 04:28 PM
apex1
you have not even the ability to read my posts, let alone to comprehend them!
On top of that your amateurish recommendation of polyester for a transom repair makes your contribution here not worth much, to say it polite.
  #35
Old 10-19-2010, 04:38 PM
Rep: 84 Posts: 661
Like I said Wiley it was better when you kept your mouth shut ,people only thought you were a Idiot! But your blabbering has proved you a Idiot.
Slippery when wet.
www.cheetahcat.com
  #36
Old 10-19-2010, 05:10 PM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Please take the fight outside guys. The input on the topic at hand is much appreciated, but all the insults and rudeness ruin the discussion.
Closed Thread
Hull repair advice needed Darce Fiberglass and Composite Boat Building 3 02-09-2009 02:36 PM
Advice needed on deck repair skullhooker Boatbuilding 7 02-22-2008 09:41 AM
Transom repair advice needed MotorHead Fiberglass and Composite Boat Building 23 12-17-2007 08:25 AM
transom repair advice CIG29 Fiberglass and Composite Boat Building 17 11-23-2006 08:28 PM
got bit... info needed on FG repair (transom/stringers) dem45133 Fiberglass and Composite Boat Building 3 08-01-2006 08:12 PM
