Old 11-28-2007, 07:29 PM
Rep: 3125 Posts: 9,399
You don't need a lifting eye, many things will easily yank that engine off your transom. Two well fed friends can do it, a boom style of engine hoist has more then enough clearance to lift it, a come-a-long from a tree branch, a chain fall from a similar tree branch, hell, I've even used a block and tackle to hoist engines up before, when I had nothing better. It's not that heavy, doesn't have to lift very far and isn't a real big deal. Have a hand truck near by so you can wheel the beast to some place safe.
Charlie had it right and unfortunately you only have two choices (three if you count doing nothing), removing the material in the transom or drilling, likely around several hundred holes.
This isn't that uncommon a repair, more often seen on delaminating plywood bulkheads or sheered cores that would prove very difficult to remove or replace, but it'll work here as well.
Once the outboard is off the transom, lower the tongue jack as far as it will go. This will cant the transom pretty plumb, so it doesn't fight you as you fill the holes. If the transom isn't plumb or better actually facing up a little, then jack the trailer axle up and support it, so the bow can drop down more with the lowered jack.
Start drilling holes, say 1/8" or 3/16" on 1 1/2" centers (yep, that's going to be a lot of holes). Drill at a downward angle (10 degrees is good) to help the goo flow into the hole. When you're drilling you'll feel the voids after the bit punches through the hull shell. When you feel this, stop and start the next hole.
You now will have a transom that looks like a well organized pin cushion. It's goo time. Mix up a very slow batch of epoxy and add some milled fibbers, until it is a very loose, very running, milky mixture. It has to flow reasonably well. Place this mixture into a squeeze bottle and then squirt it in the holes. It'll try to squirt out, so use some pressure to keep the tip of the squeeze bottle engaged with the hole. After several holes are filled, wipe the excess off with an acetone dampened rag, let the acetone flash off then put a piece of clear packaging tape over the filled holes (start at the bottom and work up). Continue filling, wiping and taping until you've done all the holes. Then go back and do it again. Many will not accept any more (or very much) goo, which means they're full. Some will want more goo, so fill them up and tape. Do this until all the holes will accept no more goo.
Fair and paint the transom then reassemble the shooting match. Yep, it sucks, but it's easier then ripping out all the materials and work that has been done. We've all had to go over and fix someone else's issues or rectify poor workmanship. I feel for you Skullhooker, but you're transom needs to be pretty bulletproof, especially with big HP engines hanging on them.
Old 12-11-2007, 04:26 PM
rwstoney's Avatar
rwstoney rwstoney is offline
Rep: 10 Posts: 4
transom rebuild
Having rebuilt the transom on a 1973 boat my one word of wisdom would be to go for a 25" transom height. The 20" transom leaves a big hole in the back of the boat where waves can come in presenting a safety issue. A 25" shaft outboard is not much more than a 20" and much safer with the higher transom.
Old 12-12-2007, 12:06 AM
Rep: 95 Posts: 462
Par when are you going to write a book
Old 12-12-2007, 09:08 AM
skullhooker skullhooker is offline
Rep: 19 Posts: 24
Oh yea, Thanks Par. I bought the lifting eye from Bob's Machine Shop, about 50 bucks delivered (otherwise a $120 dealer part), works great with my dad's chain hoist (awesome tool). motor was real easy to remove, and no sore back or motor damage.
Have probably drilled 75 1/4" holes, and am 3/4 done with filling them, has taken about three 2 hour sessions thus far. A doctor friend gave me some 60 cc syringes, which I attached a short length of 1/4" clear poly pipe with the end cut at an angle, fits tight in the holes with no squeeze-out on the sides. If the holes were taped fast we didn't have to use the acetone wipe. Acetone is nasty stuff, but your technique works great.
A weird thing is how when a hole was injected, a neighoring hole maybe 2 or 3 holes away, started oozing, like some underground gopher holes in the gap delamination. Some holes wouldnt take mach, and others I could pump one or two syringes into. The syringes gummed up in about a half an hour, then I would use another. Am waiting on more syringes to finish the job.
What a mess. With all the gaps found in the in the transom repair, I decided to pry off an aluminum 1/4" thick x 4" tall x 3" wide transom cap I previously glued down in a bed of 5200, to check for gaps under it. Well, about two inched down from the top of the transom, there was a horizontal fault line crack, which when scraped down with a mat knife, revealed that the former d*?#head repairer had formed a cap of putty, instead of a laminate cap, and simply gelcoated over. I was going to put the aluminum back on and seal it over, but then I thought that water has a way of finding all cracks, no matter how well you think you have it covered up. So now I'm gonna remove the 5200 mess, grind down the top putty, grind taper the hull and inner liner skins and laminate a top skin about 1/4" thick. Then I'll sand & fair the whole thing, re-gelcoat, glue the cap back on, and hang the motor back on. No problem , whew!
Old 12-12-2007, 03:29 PM
Good point Jack. If I collect up all the posts in every thread, I'll have a fine start. So, you want to be my editor? You can work on commission.
Yep, Skullhooker, that oozing thingie is also common. The plywood can have voids (common in exterior grades of ply) which will make perfect little highways for the goo to travel from one hole to the next (and why I said start at the bottom and work up, this way you're always filling). Syringes are the way I do it on small holes or lifted laminates, but 1/4" is big enough for my favorite squeeze bottle.
I hate 5200 for this application. You're better off filing that sucker full, grinding it smooth at the top and sealing it off with a well bedded cap.
Old 12-12-2007, 05:00 PM
Rep: 19 Posts: 24
Par, what kind of squeeze bottle do you have, something like a refillable catsup bottle? I have a couple, but it looks like I would waste a lot af material and the cap might pop off when presuure is applied.
And what do mean by filling it full and sealing it off with a well bedded cap? The aluminum cap I made is also for abrasion resistance cause I'm always stepping on it when boarding from the swim platform, smacking it with fishing rods, nets, gaffs, skis, etc. (and the boat originally came with a similar lighter gauge alum cap from the builder),
Old 12-12-2007, 08:22 PM
Fill it with epoxy, grind smooth, then cap with your bedded aluminum angle stock.
The squeeze bottle I use is a 15 year old remnant from a "Get-Rot" kit. It's about a 6 ounce bottle with a screw on top that has a tapered spout. The spout is cut, so there's about an 1/8" hole in the end of it. It's narrow enough to slide a piece of 1/4" tubing over for hard to reach areas and I've been using this "favorite" bottle of mine for years. I've seen similar on one of the major epoxy manufacture web sites (West, System 3, etc., don't remember which).
The small bottle forces me to use small batches, which is good as it'll kick pretty quickly in the confines of a bottle. I rinse it out with vinegar and a final rinse with a special epoxy cleaner.
Unless you're working directly down hand, you'll waste some epoxy, but small amounts really. I get more on my shoes then I waste.
Old 12-16-2007, 05:46 PM
ratrace2's Avatar
ratrace2 ratrace2 is offline
Rep: 84 Posts: 542
Need to Vacuum after chinking with mat:
Originally Posted by skullhooker View Post
Hello, I'm in the final stages of a major transom repair on a 19' center console fishing skiff, and have over 3 grand invested, so I can appreciate the advice above. I removed the inner liner, sawcut out the inner transom skin, removed all the rotted plywood, then ran out of time and energy. I hired a fiberglass repair guy to complete the job, and gave him all the materials.
I eventually took the boat away from him because he was trying to scam at every opportunity, and am almost finished. I finished repairing the stringers, scarfing and tabbing into the transom, dropped the inner liner back on, joined the transom, and rescrewed the hull-deck joint.
I had the omc dealer re-mount my 140hp envirude outboard using their bolt jig. They siliconed the bolt holes.
Now while re-drilling the holes for the scupper drains and transom splash well drains, I found a gap (about 1/8")between the outer transom skin (about 3/8" frp) and the new plywood. The repair guy was supposed to bed the plywood with layers of mat and clamp thoroughly to prevent this. At least the new plywood had one layer of mat stuck to it to keep it dry.
I have been flowing slightly thinned epoxy into the crack (about 16 oz. already and the level is only about 8" high) and is taking forever. I need to inject more epoxy and am thinking about tapping some holes, connecting threaded barb fittings, connecting a hose and funnel to gravity feed/force in more resin. Any suggestions would be helpful.
Also I am wondering about the motor bolt holes, and if the gap exists there, I need to remove the motor, and fill the gap there also. My friend has a bobcat with forks and I can use it to lift my motor. Is there a special bracket to attach the flywheel to lift the motor, any suggestions for this?? Thanks folks, I will post some photos soon.
This has been a 3 year project, and I am dying to get it finished. The boat is looking good, I've replaced all rotten wood, dug out all wet foam & re-foamed, refinished the gas tank, re-plumbed all hoses, enlarged the scupper drains from 3/4" to 1-1/2", re-compartmented, moved the batteries into the center conole, added a live well under the leaning post, added a washdown pump.
I'm finally getting close to some minor gelcoat refinishing, then I can re-wire and run the motor controls, and get back out on the water!
I don't think I will take on a project like this again, but I have learned a lot about boat building, design, and appreciate good construction.
God, you work hard:
Ya know what I would do. I would chink that opening with mat...punch it in like I was doing a log cabin and then dril a hole in the bottom and such resin through it with a vacuum pump......
Old 12-17-2007, 08:25 AM
Rep: 19 Posts: 24
Here's an update: This weekend I had a helper, and we removed the 5200 mess with a pair of sharp wood chisels, slicing diagonally, they cut the stuff off pretty efficiently. I then ground off the remaining stuff sacrificing one 36 grit disk, no biggie, and removed the gelcoat covering the putty. When I ground the 12:1 scarfing on the inner liner and transom laminates, the putty fell out and the top of the transom was exposed. I could now see a couple of pieces of 3/8" plywood stuffed in between the double 3/4" transom and the inner liner. There was a 4" horizontal gap on one side of the splash well, and a 2" gap on the other.
It was a lot of demo but now being able to see the gaps, I taped up the many holes drilled, and stuffed a bunch of folded up roving into the gaps, and poured resin in. Then I bought some foam board, and made an inner and outer form template, level and positioned, and staple gunned them to the exposed wood. Then mixed up about 24 oz. of resin, mixed with fibers and wood flour (all the filler materials I had) and shoveled the material in the form, troweling it off with a putty knife. It filled all the gaps, and bonded rock hard.
Now I will apply some more filler to fair the sides of the new core, grind, and lay up the laminate. It's been a lot of work, but this transom is gonna be solid if it kills me.
Photos added, one shows the crack(see arrows pointing) under the 5200 mess, and the other after grinding, forming, and filling. The white stuff is the paper from the foam board stuck to the resin.
Transom repair advice needed-5200-large-.jpg  Transom repair advice needed-ground-down-large-.jpg
transom repair cflood Boatbuilding 9 07-09-2009 10:02 AM
transom repair advice CIG29 Fiberglass and Composite Boat Building 17 11-23-2006 08:28 PM
Transom repair question robbieinga Open Discussion: All Things Boats & Boating 5 08-27-2006 04:55 PM
got bit... info needed on FG repair (transom/stringers) dem45133 Fiberglass and Composite Boat Building 3 08-01-2006 08:12 PM
transom repair andrew Fiberglass and Composite Boat Building 4 01-25-2005 09:38 PM
