Old 11-01-2004, 12:25 PM
andrew andrew is offline
Rep: 10 Posts: 2
transom repair
Hello all,
I have a 1989 17' Nissan fiberglass boat "V" hull with a 90 HP Nissan motor on the back. My transom is soft and i need to repair it. I have been talking to some mechanics and they said it cost about a thousand dollars to repair. I can do it myself for about 3 or 4 hundred dollars. I need some basic help on transoms: like the width of it, what sort of brackets could i use to bracket it to the supports that run the length of the boat. Should i use sheet metal or marine plywood. I also had a suggestion to put two 3/4" of marine board and 1 sheet of aluminum in the middle then fiberglass the whole thing. If anyone has any suggegstions or has done this to a boat before i would really appreciat the help.
thank you,
Andrew
Old 11-01-2004, 02:32 PM
Rep: 66 Posts: 640
Repair it as it was original. That way you don't have to rethink the whole structure and you'll be done with it for the next 15 years.
Dutch Peter
Old 01-25-2005, 12:07 PM
rookie repair m rookie repair m is offline
Rep: 10 Posts: 2
I repaired my transom and replaced it only with plywood. try www.transomrepair.com thats some quick deal but search for the book "how to repair fiberglass boat transoms"
Old 01-25-2005, 03:32 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Please have a look at: www.yachtsurvey.com/Fiberglass_boats.htm
Old 01-25-2005, 10:38 PM
HWL HWL is offline
Rep: 10 Posts: 18
I have replaced a few transoms like you have , and have had good success with using plywood layers totally encassed with fiberglass built to the original thickness and pattern
Transom Bracket on a 19ft boat CapeCodder Powerboats 6 12-07-2011 10:30 AM
transom bung repair cammo Fiberglass and Composite Boat Building 1 10-03-2005 09:39 AM
1975 Kingfisher Transom & Stringer Repair Kingfisher Fiberglass and Composite Boat Building 4 05-28-2005 10:17 PM
Structural Repair of Fiberglass Hull Randytea Fiberglass and Composite Boat Building 8 10-07-2004 06:32 PM
Composite Question, filling transom holes foca Powerboats 5 07-10-2004 12:46 AM
