Old 12-06-2010, 11:18 AM
SeriolaDumerili SeriolaDumerili is offline
Rep: 10 Posts: 20
Transom platform
Hello everybody,
I want to build a transom platform for my GradyWhite. Should carry about 150 kg's. My idea is to insert 5 pieces of L shape foam (in the drawing is only three). Between these reinforcements are thru hull bolts. I will infuse epoxy and I have enough 200g carbon for 3 layers and 450g biax cloth. Can you give me some hints about fiber and and foam thickness? How many layers on the bolts side?
Thank you in advance
Old 12-06-2010, 11:40 AM
mark775
IMO, forget the foam, put two more verticle braces (like the sides of the thing), even out your bolts top to bottom (spread out their load, you can't put them all at the bottom and with a platform like this, you can't put them all at the top either as the forces from under the platform will be multiples greater than the weight of 150 kg. on top - and you don't want them in a row). There are people here better suited to advise on laminate schedual. post pictures as you progress. - Mark
Old 12-06-2010, 12:28 PM
Rep: 10 Posts: 20
ok, I can put two bolts vertically connected with a backplate. Your solution with braces is better, these tight corners on braces will kill me - it will be very dificult (for a novice like me) to place all the fabrics and tubes under. Maybe is beter to infuse without braces and laminate after.
thank you for your answer
Outboard Platform or Cut-down Transom? CarbonFootprint Propulsion 18 10-25-2010 04:12 PM
swim platform toolsinbox Boatbuilding 3 10-03-2010 12:05 AM
cheap tubular swim platform / tubular platform supports Paul aka watertaxi Powerboats 0 07-08-2009 03:37 PM
Casting Platform duckdog Boat Design 0 12-12-2007 09:56 AM
SWATH work platform waterballast Boat Design 4 12-21-2005 11:31 AM
