| transom hi i just bought a very old fiberglass boat it is a delcraft. the transom is rotted . i would like to rebuild it. can anyone give me directions. i was thinking to cut it out then stitch a piece of marine plywood to the side walls then add thickened epoxy then cover the new wood with fiberglass and clear epoxy. but will it be stong enough to hold the motor , the side walls are not thick they appear to be thin fiberglass i think it is fiberglass it is not would. can anyone help explian if im onthe right course. thanks bammy the bass |
| Check the recent discussion thread on transoms. If you replace what was there the same way your motor power rating should not be changed. |
| Transom Bracket on a 19ft boat | CapeCodder | Powerboats | 6 | 12-07-2011 10:30 AM |
| BassBoat Drain area, below transom rot HELP!! | northrivergeek | Powerboats | 4 | 12-12-2005 08:06 AM |
| Attaching stringers to transom? | mikkyle | Fiberglass and Composite Boat Building | 3 | 12-13-2004 03:21 AM |
| plywood rotting in transom - grp boat | brian c | Fiberglass and Composite Boat Building | 2 | 10-07-2004 06:54 PM |
| Composite Question, filling transom holes | foca | Powerboats | 5 | 07-10-2004 12:46 AM |
