Old 03-06-2011, 11:18 PM
n421fn n421fn is offline
Rep: 10 Posts: 6
Top Side Paints
What are the best White topside paints for a fiberglass boat?
Thanks!
Old 03-06-2011, 11:23 PM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 655
Thanks!
international marine paints have a terrific range of 1k and 2 k paints to suit, look up their site and you should find what you need.
Old 03-07-2011, 08:13 AM
Rep: 1493 Posts: 7,447
The term "best" depends on the application. What characteristics are you requiring? For example, gloss retention, ease of application, possibility of touch-ups and polishing, etc.
Old 03-07-2011, 09:19 AM
Rep: 10 Posts: 6
I'm sanding down and repainting and old fiberglass boat. Looking for something affordable at reasonable price.
Old 03-07-2011, 10:45 AM
Rep: 670 Posts: 2,457
International polyurethanes are price competitive and produce a good finish .
Ive always used awlgrip products. The colour awlgrip "Off White" is a very fine paint for roll and brush application. What makes it a fine paint is the system of brushing catalyst and brushing reducer. Awlgrip is very expensive paint.
When painting a fiberglass hull the system is...sand and surface repair the topsides....apply two coats, coat on coat, of 545 primer...sand 545 primer carefully with 320 paper on a sanding block... then two coats white topcoat paint, sanding with 320 between coats . Thin the topcoat paint 25 to 30 percent. If you are careful and work correctly you will produce a perfect finish .
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
With that requirement, go to your local hardware and get Rustoleum. Its good paint at less than half the marine equivalents (Brightside and Unipoxy).
Tom Lathrop
Old 03-07-2011, 02:23 PM
I agree, any industrial grade alkyd is fine. It can also be polished to get scuff marks.
Old 03-07-2011, 06:44 PM
MastMonkey MastMonkey is offline
Rep: 43 Posts: 90
Modern latex acrylic house paints are probably better than marine paints of the not too distant past. Since it is for decks look for one that has skid resistance.
Old 03-07-2011, 10:28 PM
Rep: 10 Posts: 6
Is this a good top paints?
http://bigpaintstore.com/rus-207000.html
Offer: true go anywhere Trawler to build "side by side" apex1 Metal Boat Building 231 12-14-2010 10:40 PM
BOTTOM PAINTS - Wearlon and other new paints naturewaterboy Materials 17 02-24-2008 05:24 PM
one side plywood, one side fiberglass/epoxy, polystyrene core? murv Materials 4 05-18-2007 07:06 PM
canting keels: how are they displaced from side to side? Thaddeus Boat Design 5 10-02-2005 04:22 PM
side by side centerboards? Ian Boat Design 8 01-02-2005 08:24 PM
