Old 08-01-2008, 09:25 AM
emresandan emresandan is offline
Rep: 10 Posts: 5
Top Coat Material for serial production with epoxy and female mould
hey guys,
What is the best top coat materials for manufacturing serial boat with Epoxy which I can use in female mould.
But I want to remind again,I am doing serial production with female mould.The problem is generally gelcoats are polyester based ant they don't stick with epoxies as you know.
Vinlyester and epoxy gelcoats are mat and colours are changing after a while.
And making paint application after demoulding the product, is to much cost,labour work and time for every boat.
What are your suggestionsss ,PU in mould coats,some polyester gelcoats like sicomin.. etcc.Please specify brand name of the productss..
Thanks in advance.
Old 08-04-2008, 02:23 AM
Rep: 10 Posts: 5
any suggestion?
Old 08-04-2008, 03:47 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
emresandan,
Looks like no one has said anything so here goes.
It may be your term Top Coat that scares them off, i assume that you are referring to the gelcoat, the first layer that is used in the hull of a female mould, as you do use this term in some places of your question.
You can use good quality polyester resin based gelcoats (Scott Bader in your part of the world would be able to help) as the first layer, the vinyl ester and epoxy resin that will follow are quiet compatible to the polyester resin based gelcoat substrate. It is when you try to put poly over epoxy that the problems may start.
Old 08-04-2008, 05:36 AM
CTMD's Avatar
CTMD CTMD is offline
Naval Architect
Rep: 117 Posts: 196
Talk to one of the better resin suppliers Gurit, ATL etc. There are systems available now to get around this issue. Basically they're modified epoxies for use on the first few layers.
Chris Tucker Marine Design
Your Boat Your Way.
www.ctmd.com.au
Old 08-04-2008, 01:45 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Or just forget the top coat and paint with 2comp poly when done.. mmmmuuuuch better..
Applying gelcoat as top coat wet-foot Materials 26 12-11-2011 11:48 AM
Epoxy in mould gary1 Fiberglass and Composite Boat Building 2 06-27-2008 04:54 AM
Production FRP Mould Maker Required in China Sunshine-jiang Services & Employment 0 01-29-2008 08:50 PM
Lightest layup for a female deck/coachroof mould Roly Fiberglass and Composite Boat Building 2 10-12-2006 01:14 AM
epoxy to gel coat bonding Guest portpenncrab Boat Design 1 10-22-2003 08:44 PM
