Old 02-11-2008, 11:51 AM
rsbaker rsbaker is offline
Boat Building Coordinator
Rep: 10 Posts: 2
Tooling Gel
On production Tools ( Molds ) repairs to the tooling gelcoat, Black in this case.. return to haunt us in the form of a hazy haylow after several cycles.
Does tooling gel Post cure diferantly ? or what is going on ?
Old 02-12-2008, 02:33 AM
ondarvr ondarvr is offline
Rep: 226 Posts: 636
It's common to have a repair become dull after a few parts if it didn't cure completely and this under cure can be for many reasons. Check the age of the tooling gel you used, the fresher the better, make sure the area is warm enough, 75F or better, catalyze at 2% and you can use a patchaid type product if needed. Also some tooling gels don't work as well in a repair as others do.
Old 02-13-2008, 09:50 AM
Rep: 10 Posts: 2
Thanks for looking at my problem. We are using a CCP tooling gel Stypol 040-2989 at this time.Do you have any recomindations for a brand or particular product? that might preform better.? BoB..
Old 02-13-2008, 11:35 AM
Rep: 226 Posts: 636
The code you listed, 040 2989, is a straight ISO resin not a tooling gel, this resin is frequently used to make tooling though. There will be a code that starts with 945 or 965 on the pail.
Orange tooling Gel help j2nh Fiberglass and Composite Boat Building 22 09-30-2006 04:04 PM
gel coat instead of toolin gel ? meredog Fiberglass and Composite Boat Building 5 08-10-2006 09:53 PM
Tooling gell??? Deep Vees Only Materials 2 01-15-2006 11:14 PM
Tooling Up Thunderhead19 Metal Boat Building 15 09-28-2004 11:12 AM
tooling for rotational moulding grob Boatbuilding 3 06-08-2004 02:54 PM
