Old 06-17-2009, 11:02 PM
Steve W Steve W is offline
Rep: 315 Posts: 638
Exactly what Par,pescaloco and gonzo have recommended, your not polishing the damned thing, 24 thru 40 grit will get the job done ,even 40 is getting a bit too fine.
Steve.
Old 06-18-2009, 01:20 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
Originally Posted by Jimbo1490 View Post
The Festool RO150 and the Makita BO6040 are no mere 'random orbit ' sanders; they are triple action beasts that with the flip of a switch change action from random orbit to epicycloid (geared orbit) to true rotary grinder/polisher.
Jimbo
Interesting. The Makita--- how much? Any case, I meant that a typical strictly RO sander is more suited to finish work, while a typical angle grinder is fast and powerful and cheap--- and well suited to material removal..
Old 06-18-2009, 02:06 AM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
I'm sensing a theme here...heavier grit, slower speed, less dust. Good discussion, thanks to all.
The Makita can be had for $285 new and about $100 less as "reconditioned"
http://www.tylertool.com/makbo66varsp.html
Doesn't seem too bad for a pretty versatile tool.
Old 06-18-2009, 09:34 AM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Pawn shops have that stuff. If they ask $100, offer them $25. You'd be surprised how much they'll deal.
Old 06-18-2009, 07:40 PM
Rep: 2891 Posts: 8,798
Trust me, a cheap Harbor Freight tool will serve you fine. Paying a few hundred for a tool you'll not use very often just seems silly. Now, if you're making a living with the thing, it's a different ball of wax . . .
Old 06-18-2009, 11:18 PM
Rep: 527 Posts: 792
The BO6040 is one of Makita's hottest products; a HF copy can't be far behind. Some recent HF tools have been pretty good. I wish I could say that about their recently re-vamped 7" sander-polisher, which is exactly the tool you would use for heavy composite grinding.
I'm working on a 'mini yacht' over in Merritt Island and bought one for the job at the HF store in Melbourne, since all my 'normal' tools are air tools so no good for a boat on the water. It lasted one day before the switch quit (OK yes I pushed it pretty hard, but that's what you do with these things ). They swapped it out, no questions. But the replacement is starting to get intermittent, just like the first one did before it took the dirt nap.
Jimbo
Old 06-19-2009, 04:12 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Seajay, you might want to try some ZEC discs on your grinder too. All the best in your dusty endeavours from Jeff.
Old 06-19-2009, 04:32 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
usually I do not contribute to threads where a 100 people can and do respond
But after 45 years using power tools I have found, that, one can NEVER EVER , save on tools
For instance, I bought a 9 inch AEG grinder in 1972, it is still going strong, then I tried things like Colt, which in pro use lasted just days
If you are a handyman, then buy best, heck you can leave the tools to your grandchildren, If you are pro, then those tools are , there for you, always
In Alloy building 5 of us went through one hand electric saw a year We used Aeg, Bosch, Makita, this is sawiung long cuts, maybe 30 mins at a time, when the saw would start to chatter
Sanders(orbital) Ryobi etc,
same with hand tools, chisels, planes, screwdrivers, buy best with best reputation
www.**********************
Old 06-19-2009, 05:47 AM
gary1 gary1 is offline
Rep: 33 Posts: 157
Evening,
I am with with Whoosh 100% on this, mate buy the best sander you can afford. When I was building my boat I started of buying the el-cheapo sanders that the market is flooded with these days thinking they will be all that I will need, now not having a lot of fibre glassing experience they would get a fair work out.
When I finished the boat I had gone through a total of 13 sanders number 13 being a Bosch which cost me a fair bit of cash but was the only one that handled the punishment I was putting them through and I still have it. The other 12 cheap ones which I ende up buying 2 at a time were just false economics considering I would have a 240 klm round trip to replace them each time. They would burn out become clogged with dust broken switches you name it they stuffed up some way, except for one which I flogged up the side of a tree for 5mins but that's another story.
Buy the best name brand you can afford trust me you won't regret it.
Gary
  #25
Old 06-19-2009, 06:07 AM
waikikin's Avatar
Rep: 513 Posts: 940
I'll second & third Whoosh & Gary on the quality tools, I've had most of mine for nearly 3 decades,- as a first year I invested in bosch, aeg, makita & along the way some rupes & festo & still have most of the originals- a bosch 9" grinder & bosch jigsaw wore out at about 20 years but were well & truly "paid for", occassionally I've bought a cheapy for a specific job but they usualy dont last, also blow out your machines with compressed air esp' when grinding glass. Regards from Jeff.
  #26
Old 06-19-2009, 07:36 AM
stilloutoffocus's Avatar
stilloutoffocus stilloutoffocus is offline
dealership repair flunkie
Rep: 10 Posts: 29
i wholeheartedly agree with the harbor freight comment. I just recently replaced my HF angle grinder because the dust had gotten into the switch so bad that it wouldnt turn on or off when asked. i would blow it out with air after each use but the buildup was finally too much for the electric switches. but hey $30 for about 3-4 years of hardcore grinding is worth it to me. id feel sick to my stomach to spend 300-600 dollars for a tool i was intent on destroying.
  #27
Old 06-19-2009, 01:35 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
In case a cheapo grinder lasts long enough to the end of the project and happens to be efficent enough not to drive me in to a mental breakdown the fillings in my teeths don't..
Buy the best.. forget the rest..
  #28
Old 06-19-2009, 04:20 PM
Your choice 10 $40 sanders or one $400 sander, you make the call based on how much work you'll be doing. For a single project, it seems foolish to buy a $400 tool when a couple of $40 deals will get you through the tasks. Again, if you're making a living, then you need tools that will take you to retirement.
  #29
Old 06-19-2009, 07:06 PM
Rep: 112 Posts: 211
For the record, I just purchased the Makita 6" sander. I got a reconditioned one (same warrantee as new) for $146 from Tyler Tool. (Thanks for the recommendation Jimbo) This seemed like a reasonable all around compromise.
http://www.tylertool.com/bo6040r.html
I sort of fall into the camp of good tools are a better long-term value. I can’t remember ever looking at a tool in my shop and thinking I wish I hadn’t paid so much for it. More often than not, when one of my cheaper purchases craps out I replace it with the quality tool I should have purchased in the first place. Having said that, shelling out $500 for the Festool grinder or $300 for a new Makita does give me pause especially since I have several sanders that, according to this thread, will get the job done just fine thank you.
However, I think this tool is going to see a lot of use. While it can get about as aggressive as my 7” grinder when need be, one feature the Mikta has that the grinder doesn’t, and is important to me, is the vacuum port. Also, I think that using a sanding pad and a coarse abrasive disc will help keep my crew from grinding into the core. On the other hand, later down the line I have a lot of finish sanding to do and this is going to cover the larger areas better than my smaller sanders.
Thanks for all of the input…I didn’t expect such a spirited discussion. Also, the comments regarding grit coarseness and sanding speeds were very informative and useful. Regards to all…
SeaJay
  #30
Old 06-20-2009, 02:10 AM
Rep: 472 Posts: 1,391
Use to buy $300 name brand sanders. Now I buy 3 Harbour freight for $30 each, then get warranty on one. Every 3 months I replace one. Usually they break because we abuse them. Even expensive units will die from fine dust. Also my guys have a tendency to leave them outside or apply to much pressure to grind out metals.
As far as dust, I used thicker grit at slower speed as much as possible, I collect dust for making filler. Harbour Freight has Polisher/Sander Variable speed for between $29 and $49, I always buy then on sale and use coupons. Then fine sanding I used orbitals with vacuum. Rigid has a nice 6' unit about $150
sterndrive alignment tool martylee Sterndrives 0 05-21-2008 10:17 PM
Need a generator recommendation for small vessel drewpster Electrical Systems 16 10-11-2006 09:57 AM
Hovercraft as a Teaching Tool kach22i Education 0 05-11-2005 05:35 PM
Recommendation for an electric outboard? Mohan Pakkurti Sailboats 3 01-27-2005 11:09 AM
Recommendation software for resistance prediction?? Thong Jia Rong Software 6 10-10-2004 09:45 PM
