Old 03-22-2011, 09:26 PM
shizlenut shizlenut is offline
Rep: 55 Posts: 16
Tool for recessing foam?
I want to recess the foam on my build to leave space for laminate overlap. What is a good way to do so? I have tried sanding with an orbital but it seems slow and messy. would a electric plane work or be too aggresive? how have you gone about recessing foam?
Old 03-22-2011, 09:44 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
1708 ??? you are .045-.048 use a router and blend the little edges with a sanding block.
Slippery when wet.
www.cheetahcat.com
Old 03-22-2011, 11:18 PM
Rep: 1493 Posts: 7,447
Use the tool that is used for shaping surfboards. It is like a cheese grater
Old 03-22-2011, 11:27 PM
Rep: 84 Posts: 661
If you are gutsy a circular saw can be used,pulled sideways with the blade depth carefully set,You will need to guide from the back of the saw base ,straight edge screwed to the work,it does a clean job,practice on some scraps.
Slippery when wet.
www.cheetahcat.com
Old 03-23-2011, 03:33 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Use your wife's iron with the thermostat set for "cotton".
To avoid domestic violence when see sees what you have done, put a thin sheet of mylar or baking paper under the iron.
Old 03-23-2011, 05:16 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
You think that helps? You haven't met my wife...
You're better off providing a new iron, but do not give it to her on mothers day, her birthday, or better still, under the Christmas tree...
Best thing I have used is 2 battens, which can be screwed into the foam to act as a guide, and a router, with as large a bit as you can find.
Afterwards smooth the edge with some sandpaper.
Old 04-03-2011, 11:31 AM
Rep: 55 Posts: 16
Thanks for all the input guys, I went with the router, does a great job. I will get some pics up soon
Old 04-04-2011, 11:20 AM
thedutchtouch thedutchtouch is offline
Rep: 39 Posts: 90
in case people find this thread in the future, a hot wire foam cutter would also work.
Old 04-04-2011, 02:25 PM
Rep: 3125 Posts: 9,399
A power plane . . .
Unique new tool rasorinc Wooden Boat Building and Restoration 4 12-18-2010 05:59 AM
whats this tool Boston Boatbuilding 4 12-21-2009 04:43 PM
Tool Recommendation Please SeaJay Fiberglass and Composite Boat Building 30 06-21-2009 12:15 AM
sterndrive alignment tool martylee Sterndrives 0 05-21-2008 09:17 PM
Tool/mold heating Vanbokklen Boatbuilding 0 07-04-2004 09:45 AM
