#121
| Ok, Jim, but just my left ear...... thanks Kaptin. I guess it will only hurt for a little while. Mebbe I'll look on ebay...
__________________ Wherever you go, there you are... |
#122
| Let's say you're kinda not financially ready to pick up a Festool..... what do ya'll say about the common Bosch, Dewalt, or Craftsman DA sanders- they're definitely in my price range, and I only really need it for doing one boat, so longevity (past this project) is not a major concern.
__________________ Danny |
#123
| Personally, I'd go down to the local auto-body supply store and get a "taiwan" special for $50.00, and rent a compressor from Home depot..........
__________________ Who Said That?..................... |
#124
| The DA sander - what is the "rotex" mode best for? Do you switch back and forth from rotex to orbital while sanding?
#125
| Come on man, go buy a $50.00 DA and try both modes.......I haven't even considered what the "rotex" mode is in so long I don't even know. Ya get the stright spin for grinding and random for smoothing. "do you build them or just tune them? if ya put a little 600 on the DA you can add a full to the pitch.........
#126
| Ratrace how's your boat project coming along?
#127
__________________ hehe ,,,,,Jim------> |
#128
| Now that's funny!!
#129
| ratrace, I build and tune steel drums. Working on stainless steel construction now. Got sidetracked on this boat tho - I'll tune the drums on the boat if I can find calm enuf water to drop anchor in... hard to tune a drum when the thing is swinging around ![]()
#130
| Naturewaterboy, next time you come up to civilization give me a holler. I'll let you buy me a cup of coffee. My email is listed. |
#131
| Ok, I owe you a cup for your patience and good info - thanks very much. I'm going to get the Rotex 150 and hook a shop vac to it. I won't be doing any more work on the boat until November - have some other task to do until then.
#132
| There are a couple of places locally to get what you want, when you are ready let me know. |
#133
| the pc 6" da will work fine . for paint and nonskid removal you probably want to start with 40 or 60 grit. also you will want to replace the pad with a harder one that wiil be easier to keep things flat David |
#134
| thanx - I'll stock up on 40 grit pads. I may go visit Kaptin Jer and pick up a Festool DA with all the pads, paper and stuff, or I may just order everything on line and have it shipped - I gotta drive thru that dreaded Miami to get up his way....
#135
| International tools in Dania has a lot of tools . They are on line and ship. David |
| sanding | jbowers417 | Wooden Boat Building and Restoration | 21 | 09-20-2007 10:03 AM |
| sanding epoxy | rturbett | Fiberglass and Composite Boat Building | 16 | 01-27-2007 07:31 AM |
| Sanding and fairing | signum | Fiberglass and Composite Boat Building | 2 | 09-19-2005 01:53 AM |
| Gelcoat (sanding) | Saeed | Fiberglass and Composite Boat Building | 3 | 02-16-2005 03:35 PM |
| Flairing tool for deck drain | Greavous | Boatbuilding | 4 | 04-24-2004 09:13 AM |
