Old 01-24-2006, 10:57 AM
paularey paularey is offline
Rep: 10 Posts: 32
thru-hull trancducer install tips...?
I am installing a new RayMarine depth finder in my Catamaran (plywood/fiberglass hull) which is currently in the water. I want to make and bond my inside fairing block for the transducer (1.87 inch shank). Also I’ll probable finish the job when I’m beached somewhere so I need to have all my prep work done so the job goes quickly. Any tips on a good fairing material and how to best approach this project for a leak proof install is appreciated.
Old 01-25-2006, 03:09 PM
Darren Darren is offline
Rep: 10 Posts: 11
There is a new transducer available that looks through the grp hull, therefore no drilling required
We have just started using them in a large international company !!!!!
tips on spraying gelcoat? H2Only Fiberglass and Composite Boat Building 11 12-27-2005 11:39 AM
Which Jacuzzi to install in my Boat? the big jetski Propulsion 4 12-14-2005 03:46 AM
Why install a Wet Manifold? rjohnbriggs DIY Marinizing 19 08-30-2005 11:39 AM
how to install a P-bracket? Ivan R Fiberglass and Composite Boat Building 6 11-22-2004 01:49 AM
Backing Rudder tips? fastfred Powerboats 3 06-27-2004 03:18 AM
