| Thoughts on mold waxing procedure I have always hand waxed / removed mold release wax from a mold or plug. is anyone using a machine? and if so at what rpm. to keep from burning through the wax? We apply approx 7 coats with allowing the polished off surface to rest a bit before appling additional coats. |
| Power buffing - waxed molds Quote:
By the way - after you put the wax on - you should wait for several minutes - for the solvent to come to the surface - before doing any polishing - - then when the job has been polished - again wait for several minutes for the rest of any residual solvent to come to the surface (you'll see it 'blush' on the surface) - then polish it up again - before applying another coat of was. I M H O - Ciao, james |
| Please do source a datasheet on your wax, and see if your procedure meets that instructions in the datasheet. My experience: apply wax as thin as possible with a rag or applicator leave to blush off for 1 or 2 minutes (wax goes matte) break the surface with a clean cloth leave to cure for 15 minutes or so polish to a high shine, with a clean cloth. (another one than the previous) You will go through cloth like crazy, as they foul up pretty quickly, but at least the process is not tedious. Another option would be to look into semi permanents. So much easier to apply. (the one we have is a matter of wetting the surface with the semi-perm, then taking a fresh piece of paper and keep wiping the surface untill it is dry. 2x sealer and 1x release is all you need, then perhaps every 5 or 10 parts a new application of release. Appication of the release should be done by the people that demould the parts. They know when it is time for a new layer of release.
__________________ Airex C70.55 SC for sale (now updated with amounts and prices) |
| James what do you use for a removal pad? Thanks Herman I will look it up! |
| thanks always a great source of info ! |
| i am a painter by trade but am currently helping the mold makers. I also asked about why they use hand buffing "cos we always have" was the answer. I understand the "don't fix what ain't bust approach" but it seems kinda daft to me to be buffing up the wax by hand when a machine would do it way quicker. I wouldn't sand a 70footer by hand, why should I buff the mold wax by hand? (I thought wrapping rags around a convention mop head would do trick. It would allow you to use clean cloth every so often).
__________________ Regards Colin |
| why should I buff the mold wax by hand? ....cos you are then sure that it has all been done and done well, critical part of the process, and yes we used to do 80 footers by hand too
__________________ My short-term memory is not as sharp as it used to be. Also, my short-term memory's not as sharp as it used to be. |
| 23 meters, and waxed by hand with Meguiars M87
| 28 metres and all done by hand hull and deck and fly bridge !! ![]()
My comment on machine was with the buffing to gloss, not application. A machine would do it quicker. If you missed a bit it would be still cloudy, so you would be able to see it. I am very willing to be persuaded of technical benefits of hand buffing but so far I haven't heard anything and machine buffing would be way quicker. What's the risk. (and I as I said I am all for don't fix what ain't bust but I am also aware of increasing cost constraints)
| Why take it off by hand? Because a buffer takes all the wax off you're trying to build up. We learned this lesson the expensive and hard way. It was the "Old timers" we hired later who explained what we were doing wrong and why. Never a problem since, knock on fiberglass. -jim lee |
| thoughts on finish in a mold | brokensheer | Fiberglass and Composite Boat Building | 4 | 02-24-2012 02:07 PM |
| Waxing over semi-perm release agents | Dresca | Materials | 0 | 05-20-2008 05:04 PM |
| Mold polishing procedure? | Willie | Fiberglass and Composite Boat Building | 9 | 11-14-2007 09:03 AM |
| Mold Waxing | Agewon | Materials | 7 | 08-18-2007 12:20 AM |
| anyone to help on freeship hull fairing procedure?? | yades | Software | 7 | 09-15-2006 12:03 AM |
