Old 08-31-2010, 11:55 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
a thought during the building process!
Any one building boats to sail offshore would usually carry a radar reflector so they can be seen by ships and in the case of lost at sea be spotted by A search plane .
I was fortunate to make a couple of 22foot high speed tunnels boats for a couple of guys that belonged to the coast guard . In each boat deck and the topsides of the hull the first layer of glass behind the gelcoat had aluminum coating on the glass !!
Its a tissue and is easy to lay at the same time as the first csm gets laid .
The end result was not a bleep on the radar but it glowed from a long long way off and in the case of the tests done by the search and rescue aircfaft it was spotted immediatly on the edge of there screen .
So food you thought !!
The tissue was origanally used in the plastics industry for sheilding inside the plastic casings of some computer parts .
Have also heard of using aluminum fileings mixed with resin to get a simular effect .
Not only need to be seen from ablove but also at sea level to .
Every little helps !!
Old 09-01-2010, 08:50 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
Interesting
Thanks
Old 09-01-2010, 10:40 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
That's really an interesting idea.
Makes me think about about that pile of aluminum shavings uselessly laying on the yard floor...
Old 09-01-2010, 11:04 AM
susho susho is offline
Composite builder
Rep: 62 Posts: 66
What about texalium? (glassfibe with aluminium coating)
Old 09-01-2010, 02:16 PM
old one !
At the time of building i was very septical abot the whole deal but a while later i heard of others doing a simular thing as i said with fileings . The other spin off was less radio interferance from other equipment . Dont know about a compass but ? most people have gps and radar and sounders and all manner of electrical goodies anyway .
The picture was the slightly bigger brother of the same design , twin 200 yamaha"s a big cockpit and a really exciting boat to drive !
Old 09-02-2010, 01:52 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Hmmm, I know plenty of people not wanting to be seen on any radar. They have similar boats, but with 5 outboards on the stern, and sail at night...
Old 09-02-2010, 02:02 PM
old one !
Yeah lots a people have something to hide !!
Old 09-02-2010, 03:20 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,054
Maybe this works too..
http://shop.r-g.de/en/Fillers/Filler...aram=aluminium
(the photo on the page isn't the product)
Aluminium powder
•For enhancing the hardness of pouring and moulding compounds
•High thermal conductivity (e.g. for deep-drawing dies)
•For epoxy, polyester, and vinyl ester resins
Fine, powdery aluminium powder as an additive for pouring and moulding compounds. It enhances the impact and compressive strength of moulding compounds, and its low resin content helps to reduce shrinkage.
Technical data:
Particle size: > 63 µm n
Density: 2,7 g/cm³
Melting point: 660 °C
Old 09-02-2010, 03:48 PM
daiquiri's Avatar
Could work, but aluminum shavings on the floor are for free.
Old 09-02-2010, 03:51 PM
old one !
Aluminium powder
Technical data:
Density: 2,7 g/cm³
Yeah same sort of thing but not to the amount they would use . Made vac forming moulds for acrylic sheet and they had the same as what you have listed . The tissue was readerly availible so thats the reason it was used . in our case .
Old 09-03-2010, 01:41 AM
TeddyDiver's Avatar
Gollywobbler
The reasoning for the powder are the other ones rather than the radar reflection ability (It enhances the impact and compressive strength) So it would be only an additional advantage (or disadvantage )
Old 09-03-2010, 02:22 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
"Dont know about a compass but ? "..........alloy mate, so it will not have any affect at all.......unless of course it was a Kiwi compass, then there may be some deviation....
Old 09-03-2010, 04:00 AM
Composite builder
Rep: 62 Posts: 66
There are other materials we use in boatbuilding wich could be used for that
Old 09-13-2010, 04:14 AM
old one !
I believe the world is flat !! AND i never sail out of sight of land . Dont need a compass !
Old 09-13-2010, 04:37 AM
Landlubber's Avatar
...the world is flat, I can see it from my window.....
The thought police are alive and well aussiebushman Forum Questions and Suggestions 7 02-04-2010 09:29 AM
Just a thought rambo! Boat Design 41 09-30-2009 05:42 PM
In Case You Thought I May Be Crazy... Sean Herron Open Discussion: All Things Boats & Boating 12 01-20-2009 03:06 PM
Thought I would post an Intro! Steven Brown Open Discussion: All Things Boats & Boating 1 05-30-2004 05:44 PM
thought on fuel cells boats4future Boatbuilding 1 11-20-2002 11:44 AM
