| So what's the word on aluminum powder and reflecting radar? The aluminum is coated so it won't conduct electricity, and with the very small particle size I don't know if it would help much or not. Maybe large metal flake like a 70's bass boat would do the trick ![]() |
| graphite coating is used to absorb radar reflection, carbon fibre should have the same property. (swedish visby class is made out of cf for that reason, and weight savings.) |
| The specifications for the ground plane I have mounted calls for stainless steel wiremesh with mesh opening of less than 2 mm. The wiremesh is embedded in the uppermost layer (near the gelcoat) and electrically connected to the ground plate through copper strips. There is an aluminum (conductive) coated WR used in large sattelite dish but the OEM did not allow it. Works out ok though. Expensive but it works well on fiberglass sattelite dish. |
| The thought police are alive and well | aussiebushman | Forum Questions and Suggestions | 7 | 02-04-2010 09:29 AM |
| Just a thought | rambo! | Boat Design | 41 | 09-30-2009 05:42 PM |
| In Case You Thought I May Be Crazy... | Sean Herron | Open Discussion: All Things Boats & Boating | 12 | 01-20-2009 03:06 PM |
| Thought I would post an Intro! | Steven Brown | Open Discussion: All Things Boats & Boating | 1 | 05-30-2004 05:44 PM |
| thought on fuel cells | boats4future | Boatbuilding | 1 | 11-20-2002 11:44 AM |
