| Thining Gelcoat: Acetone or Styrene? Any suggestions on thining gelcoat to spray. WIll acetone degrade the strengths of gelcoat and will styrene discolor? I've heard/read mixed stories. ![]() |
| Yes to both, for both. neither one is recommended, but people use them all the time. There are products formulated for reducing gel coat to help it spray and cure better, you can get them at most fiberglass supply outlets. If you can't get the right product, you can use acetone or styrene, just don't use more than about 5%. |
| Spraying gelcoat over gelcoat | alexhiguera | Fiberglass and Composite Boat Building | 9 | 08-26-2005 11:09 PM |
| gelcoat | Jorge | Wooden Boat Building and Restoration | 8 | 08-25-2005 07:24 PM |
| gelcoat | KBbricker | Fiberglass and Composite Boat Building | 3 | 08-20-2005 02:00 AM |
| % of styrene in polyester resin for wood bonding | jfblouin | Fiberglass and Composite Boat Building | 6 | 02-24-2005 05:45 AM |
| GelCoat | JamesR | Fiberglass and Composite Boat Building | 1 | 01-07-2005 07:19 PM |
