| teak rubrail backing When I took off the teak rub rail I found a rubber like 1/16" tackly strip on the back of the teak strip. What purpose does it serve? Can I eliminate it and just screw the bare teak back onto the hull? If it serves a useful purpose, what product do I use? William C. Winslow |
| It might cover the hull / deck joint and provide some watertightness at that critical spot. Any further info on the boat? Material, size, brand? Pictures? Regards Richard |
| It might cover the hull / deck joint and provide some watertightness at that critical spot. Any further info on the boat? Material, size, brand? Pictures? Regards Richard G The boat is a Cornish Crabber, a 27' Britich design, 2001, fibreglass hull. Will send pix if I can figure out how to do so. I would think if they wanted a watertight seal, they would have coated the back of the teak with 5200, but what a bitch to take off. |
Not sure they would have used 5200! Maybe they used Sikaflex or similar. And maybe it was only there to protect the backside of the teak rail from water ingress? And, why not asking the manufacturer directly? Regards Richard |
| bedding/backing through hulls | pasty63 | Diesel Engines | 12 | 01-14-2009 05:02 AM |
| Headliner backing | Gashmore | Boat Design | 5 | 02-19-2008 04:05 PM |
| Options for rubrail on fiberglass boat | stevel | Fiberglass and Composite Boat Building | 0 | 09-01-2006 12:16 PM |
| Backing Rudder tips? | fastfred | Powerboats | 3 | 06-27-2004 03:18 AM |
| Advice for Teak Rubrail Replacement. | Herb Morrison | Fiberglass and Composite Boat Building | 6 | 01-22-2004 08:11 AM |
