Old 10-21-2009, 08:14 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Good to hear. You saved yourself some trouble...
Old 03-18-2010, 08:14 PM
elhix elhix is offline
Rep: 10 Posts: 13
Be glad it's not blush, I've been using some Ampreg 21 a while - blushes like a... (I can't think of an acceptable simile). The amount of extra work involved in washing all the amine off a large part or section of boat is considerable. I liked the sp resin for it's low viscosity and pleasant biscuity odour but won't touch it again as it blushed every time. I'm now back using Sicomin resin which never seems to blush - go figure.
Old 03-19-2010, 02:36 AM
Herman's Avatar
Resininfusion.info
Same experience here. Which type of resin from Sicomin do you use?
Old 03-21-2010, 11:15 AM
Rep: 527 Posts: 792
Remember that the palatibility of the odor is no predictor of toxicity! The cycloaliphatic amines (Like DETA and TETA) typically smell rather pleasant but are simultaneously the most toxic of the curing agents, and can easily enter your bloodstream in significant amounts through inhalation.
Jimbo
epoxy,epoxy, opps flooring epoxy aboyd Materials 5 09-12-2009 03:56 PM
Augh, gelcoat still tacky, any suggestions sbklf Fiberglass and Composite Boat Building 7 08-05-2009 07:01 AM
West System epoxy over D.E.R 331 epoxy bobbychuong Materials 8 10-18-2008 04:13 AM
epoxy primer sprayed on green epoxy laminate? bntii Boatbuilding 12 10-16-2006 07:41 AM
how much epoxy Boatbuilding 2 07-01-2002 06:39 PM
