Old 09-30-2004, 01:14 PM
Table off Offsets?
What is the table of offsets used for in a set of plans? is it used only for constructing a mold? Also the lines view is used for what purpose?
Old 10-03-2004, 09:14 AM
Eric Sponberg's Avatar
Rep: 2447 Posts: 1,376
The lines of the boat are used to define the hull, of course, in order to build it. You have to loft the boat before you can build it, and lofting is essentially drawing the lines on a big flat floor at full scale. Then the frames of the boat are physically built and matched to the lines on the loft floor. The lines are also used to calculate hydrostatics (still water characteristics--displacement, block coefficient, prismatic coefficient, pounds per inch immersion, etc.) and stability (the characteristics of the boat as it heels).
The Table of Offsets are the dimensions of the hull lines (stations, waterlines, buttocks, and diagonals) with respect to the three reference lines: centerline, baseline, and station 0. If you have only a Table of Offsets, you can draw the lines and build the boat.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Table of Offsets for FFG-7 netjaws Boat Design 1 02-12-2011 02:31 AM
table of offsets aqua_ambulat Boat Design 2 09-17-2005 08:07 AM
newbie - Rhino - table of offsets pdavidson Software 6 08-29-2005 12:38 PM
CWL? (from a table of offsets) samh Boat Design 1 09-13-2004 05:03 AM
Input from a table of offsets johnbeavis Software 2 08-18-2004 10:11 PM
