Old 07-07-2010, 04:25 PM
boatstruck boatstruck is offline
Rep: 10 Posts: 2
suggestions for improving centerboard pivot
hello folks, new to boatdesign.net, nice to meet you all.
i have removed the centerboard from my 30' Irwin Citation and found the hole in the board has been wallowed out to a 3" groove.
i would like to reinforce this area.
i would also like the pivot to resist corrosion with the stainless pin (also missing)
the board is GRP over plywood, five feet long by 1 foot wide and weights 80 pounds.
originally i thought metal bushings but am not sure how to secure them to the board
then i thought embed a plastic bushing 3" in diameter, something that can bond with epoxy, does nylon bond well?
then i thought, let me ask some of the guys at boatdesign.net
all ideas appreciated.
thanks in advance
boatstruck (matt)
Old 07-07-2010, 10:22 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
NYLON wont stick to epoxy but look on the positive side and use the epoxy as the sleeve to retain the nylon if you add some shape to the outside of the nylon bush like square with a hole in the middle it will stay and pivot .Find a type of urethane called NYLOTHANE used for bushings in car suspensions and is really robust and tough !!all the bushs ive seen have been bright red in colour
Old 07-08-2010, 09:51 PM
Rep: 1493 Posts: 7,447
Nylon is not bad but take into account that is swells with water. Give it some clearance. It will not bond, but you can make a mechanical lock by giving a taper to the outside of the bushing.
Old 07-08-2010, 11:29 PM
Rep: 10 Posts: 2
thanks gonzo, and tunnels
i will talk to the guys at the machine shop and see what they suggest
i will let you know how it goes
thanks again
boatstruck (matt)
Improving handling in following seas journey Powerboats 40 02-15-2010 03:48 PM
Spreaders: Pivot or not Scott Carter Sailboats 2 02-12-2007 09:41 AM
pivot keel mechanism gja Boat Design 3 01-26-2007 09:32 AM
Prop change for improving hull performance Luchog Sterndrives 2 09-14-2006 01:24 PM
Improving Efficiency at 15-20kt joebobb Boat Design 18 09-02-2005 12:12 PM
