Old 08-20-2007, 12:49 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Use a 3 or 4 inch natural bristle brush and don't let the gel coat build up in the corners. A thick coat applied with a brush will be about 10 mils thick, so you'll need to apply at least 2 coats. After a couple of tries you should get the hang of it.
Old 08-20-2007, 02:59 PM
Itchy Itchy is offline
Rep: 16 Posts: 44
What are some pros and cons of brushing and spraying?
Old 08-21-2007, 09:28 AM
Rep: 288 Posts: 662
Cons
Uneven gel coat thickness, slow if doing more than a very small part, not a good method for anything but low volume production.
Pros
No investment in equipment, less setup time for a small part, no over spray.
In some countries they're not allowed to spray gel coat, so rolling and brushing are common, it does work, but there's a learning curve.
Old 08-22-2007, 02:56 PM
Rep: 16 Posts: 44
Thanks for all the info guys. This should give me enough to get this started.
Now I wonder how many pieces I will screw up until I get this right.
Stupid Question-Really Stupid Answer timgoz Open Discussion: All Things Boats & Boating 81 06-02-2007 11:58 PM
another stupid question.... hull number Moose 200x Boat Design 1 09-30-2006 08:40 AM
Stupid question hiracer Metal Boat Building 10 08-19-2006 07:55 PM
gelcoat or epoxie over glass longliner45 Boatbuilding 1 01-22-2006 09:49 PM
Stupid Question McBoo Open Discussion: All Things Boats & Boating 29 12-27-2005 06:31 PM
