Old 03-26-2004, 08:50 AM
Gone Ballistic Gone Ballistic is offline
Rep: 10 Posts: 14
Structural Joints
Hi, I'm new to this forum. I'm a keen sailor and i'm thinking about taking on a design and build project for a 30ft racer cruiser. Primarily considering foam cored composite construction. I do have a few questions about detailed parts.
1)What are the different options for the hull/deck joints. I would like to have a rounded deck edge with a v.small toe rail.
2)Keel is likely to be fin and lead bulb but again don't know what is best for the bulb/fin joint and the fin/hull joint.
Any experiences would be most appreciated
Cheers
Andrew
Old 03-26-2004, 10:21 PM
Not A Guest Not A Guest is offline
Registered
Rep: 10 Posts: 55
You want a metal connection between the bulb keel and the hull.
For the hull joint you can mold a gap between the hull and deck and then during assembly fill the gap with curved foam and glass.
CAE Structural support to sailboat design Giovi Boat Design 1 11-03-2007 05:01 AM
Are Your Glue Joints Repairable? Bob Smalser Boatbuilding 10 03-02-2006 06:20 AM
Structural Design Draughtsman seeking a Challenging Role kenlanghorn Services & Employment 2 06-02-2005 05:41 PM
which brand structural adhesives Jmooredesigns Materials 3 09-26-2004 11:11 PM
Need help from fiberglass structural expert Pelican Boat Design 2 01-18-2003 12:24 AM
