| Strongplank vs. woodcore I would like to get information on a material called Strongplank which is suggested as a replacement for wood (eg. red cedar) in a woodcore-type construction with epoxy. Advantages would be: lighter hull, slightly stiffer, better ballast/displacement ratio, no risk for delamination, no risk for rot in case of water infiltration. Has anyone experience with this material ? I am looking at construction of a hull (sailboat) of approx. 41 ft? |
| Eversail yachts are built with that stuff. I was there and I liked what I saw. It makes sense to me. Its site has an explanation about the product. It used to be also in English, now it is only in Dutch. If you are Flemish you will understand, otherwise write to them and ask for a translated paper (they have it), or even better, pay them a visit. They are nice Guys. http://www.eversail.nl/index.php?menu_id=59 |
| Thanks Vega. I've seen the Eversail site and will visit them next week at the Hiswa in Amsterdam. They seem to be the main user (promotor?) of this product. A few other yards are sited having build in Strongplank, but apparently none outside of the Netherlands. Keep info coming. |
| Experience with Strong Plank Yes endeed I do have some experience: My passt projects I supported 28`Collin archer several 35`cruiser 3 classik coasters 3 Kaptn speed boats´ 1 High speed Tender above 65 knots full Carbon / with Strong Plank 3 - 40`Saling Yards Nissen and JV Desing 1 - 60´ Sailing JV desing (small Pinta) And the largest 160 ft Schooner For what Information your searching for? rgds Robert |
| Do you have any cost and weight estimates? |
Thank's |
| perhaps here: http://www.core-and-more.de/strong-plank-system.0.html http://www.tv-enterprise.com/test/in...d=13&Itemid=27 Some more pages about srongplak: http://www.kade9.nl/Uploads/Bestande...oot-2-2006.pdf http://www.gebr-langenberg.com/evers...ank/strong.htm I hope you are Flemish ![]() |
| No A am not, but i speek a little deutch... I hope I will understand everything... or I will ask a translation at a friend... Thanks |
what do you think? regards lazeyjack the first |
| Looks interesting...I was thinking about doing the same type of thing but using veneers, glued and laminated to about 2" thick. can anyone see any problems with it ? buckie |
