| Stringers on a 3250 Bayliner Hi gang. Im new here and this is our third Bayliner I have restored and also the biggest project to date. My original stringers are 1 11/16 thick and the closest material I have found is 1 1/2 thick I have found 24' fir material for replacment stringers I like using west system so Im asking procedures here to fill the void. ie what fibreglass, Mat or roving, Should I build up the stringer before insertion to the pocket. Should I use epoxy or resin etc. Here is a link to what I have done so far. http://www.baylinerownersclub.org/fo...ad.php?t=28889 Also some photos here http://rides.webshots.com/album/569380163igEwlI Cheers Michael |
| any decent hardwoods yard will be able to take 8/4 stock to whatever size you want and its cheep to do so milling for thickness is about the cheapest type of milling round often free best of luck B |
| Hi Boston Thanks for the reply All of the mills around here do not have the 21' length that I require except for one place but thier stock is 1 1/2 so in order to keep with not having to splice III think I will have to build up one side of the stringer with roving to make up the 3/16 |
| scarf joints if done properly are about as strong as the unbroken wood might be a good time to learn how if you want to get creative you can order a microlam in what ever length you want its like a giant piece of plywood and comes in the thickness you are talking about used for structural beams in construction ask the yard about nominal sizes and you will find one at 7/4 or 1 3/4" best B |
| What am I??? (Can you identify this Bayliner ? 17 ft. I/O?) | Davie Jones | Powerboats | 0 | 03-25-2008 09:16 PM |
| Bayliner 175 cracks | havaman | Powerboats | 2 | 04-24-2006 08:11 AM |
| bayliner capri 1850 LS | praireboy | Powerboats | 1 | 01-25-2006 07:03 PM |
| Buying Bayliner | GeorgeMcCormick | Powerboats | 2 | 01-01-2006 08:24 AM |
| Bayliner 3258 shipping | Jim Mott | Open Discussion: All Things Boats & Boating | 0 | 09-08-2004 05:43 PM |
