Old 06-01-2009, 01:54 AM
jphillips jphillips is offline
Rep: 10 Posts: 2
Stringer replacement
I have removed the rotten wood from the stringers and transom, wet foam and old fiberglass from an 18.5 Quantum fish and ski. After reading some of the posts here, I realize I might have made a mistake by removing all of this at one time. What is the best way to ensure that I have a straight hull after I complete my repairs? The boat has been on the trailer the whole time, but would it be better to build a set of rails to set the boat on to make sure everything is lined up correctly? Any advice would be appreciated. Thanks
Old 06-01-2009, 05:49 AM
Rep: 2891 Posts: 8,792
Pictures would help. The obvious thing will be a hook or other type of hull distortion as a result of removing the structural elements without proper support.
Ideally, you'll want the bottom to be straight and not drooping down near the transom.
Post some picture of the hull profile, showing the lines on the bottom, such as strakes, keel and chines.
Old 06-01-2009, 10:09 AM
Rep: 10 Posts: 2
I'll get some pictures posted this evening.
Transom & Stringer replacement blaze_125 Fiberglass and Composite Boat Building 105 06-25-2009 12:03 AM
Aluminum Stringer Replacement Boater Man Materials 11 03-04-2008 05:02 PM
Another stringer replacement question mongo75 Fiberglass and Composite Boat Building 4 02-21-2008 11:51 AM
floor and stringer replacement man5 Fiberglass and Composite Boat Building 12 08-30-2006 09:00 PM
what to use for FLoor and stringer replacement jalbee Materials 2 08-19-2006 11:15 AM
