Old 01-04-2005, 04:43 PM
Aaron23 Aaron23 is offline
Rep: 10 Posts: 5
Checking Transom
Another way to check the transom core is to remove a piece of hardware that bolts all the way through, like a swim platform bracket, etc. The lower on the transom the better. Poke around the walls of the hole with a small screwdriver and a flashlight. If you turn up any rotten or wet wood it may may indicate a soft transom. Make sure you re-seal the hardware properly.
To know for sure you could drill some strategic core samples about 1/2" deep from inside the boat (don't forget to fill them back in with epoxy).
Just some thoughts.
Stringer repair ?'s scarabfreak Fiberglass and Composite Boat Building 16 02-21-2007 11:00 PM
1975 Kingfisher Transom & Stringer Repair Kingfisher Fiberglass and Composite Boat Building 4 05-28-2005 09:17 PM
Fiberglass question for final stages repair project.. Hou-Chap Materials 3 09-27-2004 10:14 AM
Yet another stringer repair post... TBarCYa Fiberglass and Composite Boat Building 16 09-01-2004 04:44 AM
Metal fatigue and more, repair question... ErikG Materials 0 06-10-2002 08:17 AM
