| Stringer When installing new stringer,what is applied under edge of stringer where it meet's hull?? 5200,cloth ?? I know about glassing it in but concerned where the stringer contact's hull. |
| I just replaced the stringers in my 17' Cobia and didn't put anything between the stringers and hull. What I did was use epoxy and filler to create fillets to smooth the transition from the vertical stringer to the hull and allow the glass to adhere properly. I had also used the same material (epoxy and filler) to fill any gaps between the hull and stringer but didn't use anything as an adhesive. |
__________________ Dutch Peter “The opinion of the majority is not necessarily correct” – Yi Qing Cui |
| Wood to use replacing keel stringer | painter | Materials | 13 | 04-16-2010 12:14 PM |
| Stringer repair ?'s | scarabfreak | Fiberglass and Composite Boat Building | 16 | 02-22-2007 12:00 AM |
| 1972 Hardtop - Stringer and glass | campbell | Boatbuilding | 2 | 06-25-2005 12:51 AM |
| 1975 Kingfisher Transom & Stringer Repair | Kingfisher | Fiberglass and Composite Boat Building | 4 | 05-28-2005 10:17 PM |
| Replacing stringer, bulkheads, floor | gbaaron | Fiberglass and Composite Boat Building | 3 | 12-11-2004 12:40 PM |
