Old 09-16-2011, 11:43 AM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
Still Struggling With Some Basic Fiberglass Stuff - Any Ideas?
My rudders are now ready for lamination.
Only problem is, I don't understand how to do it.
The plans call for two layers of 17oz (600g) triaxial that are "carried over the
top" of the rudder.
They also specify several layers of 6oz cloth on the leading and trailing edges,
tapered.
I have no idea how to put this laminate in a bag and infuse it. I don't
understand how to lay the triaxial down and where to end it.
The trailing edge of a rudder is pretty sharp. What do you do there? If you
lump a bunch of 6oz cloth of it, you will build it up to a thicker piece.
Also, where do you begin and end the triaxial lamination that goes "up and over
the top" of the rudder? Do you start at the top and wrap it around the bottom,
doing an overlap at the top? Do you start in the middle of the rudder, doing an
overlap in the middle and having a single laminate with no overlap on the top
and bottom?
Do I just put the rudder in between a couple of pieces of glass like a sandwich,
leaving all the edges sticking out and grind those off?
The rudder also tapers from the top to the bottom, which complicates this.
Where do you begin and end the cloth that goes on the leading and trailing edges
and now much does it overlap with the triaxial, if at all?
This is very *very* confusing to me since I don't understand how to do the
laminate. The plans say, "carry triaxial over top of rudder" and "use 6oz cloth
at a thickness to match the rest of the triaxial on leading and trailing edges."
For a beginner like myself, I have no idea how to make those two things happen
properly.
Can anyone suggest a method to do this? What did you do with your own rudder?
Thanks everyone.
Kurt Hughes was right about this place.
Old 09-16-2011, 02:06 PM
wet feet wet feet is offline
Rep: 99 Posts: 264
Two seperate questions for CatBuilder:Have you any vacuum bagging experience?Do you think it might be a good idea to do some practising on a component a bit less critical to the safety of your boat,to begin with?
Old 09-16-2011, 02:14 PM
Yes, lots of experience. I have an entire 45' hull up already.
My question, though possibly not clear enough, is about how to lay the glass out. The plans did not make sense to me, but I figured it's because it's my first build.
I can't understand what purpose that 6oz cloth on leading and trailing edges has.
I would imagine I just wrap triax from trailing edge, around leading edge, back to trailing edge to meet, overlapping at the top and bottom.
The 6oz cloth escapes me.
Old 09-16-2011, 03:17 PM
Rep: 670 Posts: 2,457
Typical composite rudder construction
http://www.youtube.com/watch?v=Bk5koQmEIrY
Phils Foils in case the link doesnt work
Old 09-16-2011, 05:16 PM
Ah! Just saw that as well. Thanks, Michael!
I see the orientation they use at Phil's foils and I'll do the same, meeting at the trailing edge.
Thanks!
Basic fiberglass hull . frank smith Fiberglass and Composite Boat Building 10 12-31-2010 08:08 PM
New to Fiberglass, very basic questions... science abuse Fiberglass and Composite Boat Building 32 06-29-2010 11:49 AM
struggling with interiors schwing Boat Design 4 01-09-2010 10:00 AM
12' fiberglass fishing boat-Ideas please bajapaul Fiberglass and Composite Boat Building 4 04-30-2009 10:53 AM
struggling!! snow 57 Software 6 05-05-2007 04:10 AM
