Old 12-18-2010, 08:42 AM
Darce Darce is offline
Rep: 10 Posts: 12
Stanchion Repair
I am looking for advice on the best way to repair a stanchion which has been pushed in through the deck.
I'm guessing cut through the upper skin and replace the core with a similar material before glassing top and bottom.
craapscii image below
____________________
xxxxxxxxxxxxxxxxxxxxx
___________________
Old 12-18-2010, 09:34 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
You pretty much got it,but if there is core in there replace it with solid glass,not more of the same as there should not be core there in the first place.There may not be core there but the glass where the top and bottom skins come together may be too thin in which case you will need to beef up the laminate on the inside.I will usually make up big backing plates for the inside out of 3/16" 6061-T6 alum or G10 and if there are no raised bosses on the top i will also instal an external plate to spread the point loading over a bigger area.
Steve.
Old 12-18-2010, 10:21 AM
Rep: 10 Posts: 12
How many layups of glass would you recommend? It's for a 23' 1/4 tonner IOR style yacht.
Transom repair renovatio Boatbuilding 3 07-09-2009 09:56 AM
johnboat repair paintedhorse Metal Boat Building 0 10-21-2008 07:36 PM
Boat repair A-white Boatbuilding 50 04-01-2008 07:04 AM
Fiberglass repair shop/ boat repair For Sale. W/ property on US1 boatguy64 Marketplace 1 03-03-2008 01:23 PM
Aquacat Repair uber33t Multihulls 6 04-17-2006 03:00 PM
