| Stainless steel screws under epoxy !? I just bought Water Craft (the UK-one, that is) #69, because of an article-seris of building a strip-plank Roxane (the Nigel Irens design). The author-cum-builder (Dick Phillips, who's building it for Charles and Gillian Taylor) writes this about strip-planking the hull: Quote:
Now, am I being paranoid or what? When I build mine, I used bronze screws for that part, simply because of fear of oxygen starvation even though I knew it would be very unlikely that I will ever get water in there - but then again, it's in the "corner", with loads of end-wood (can't remember the term in english), and a place where, if hit or abraded the epoxy/cloth will quickly be "holed": Enter crevice corrosion. Hell, epoxy isn't even completely water proof. Am I too paranoid? How about you guys? Which way would you choose to do it? Stainless or bronze for this part? |
| I have seen several boats being built and a couple removed the screws but in strip plank - how? look up some of the building boat books and or email the designer...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
| 316 stainless is suitable for below waterline use so what would the problem be? |
[Edit:How, you ask? It's for use at the ends where the strip-ends meet the stern and bow respectively. Using permanent screws there are the usual way to go around this task. Edit 2: I am not asking "how" to do this. Nor are we talking about the screws that one removes when the epoxy in the strips is hardened. I (and he) am talking about the permanent screws] No, it's not. Only on boats living on trailers. Otherwise you don't want stainless below the waterline where it will starve for oxygen (= crevice corrosion). |
| Danish, Maybe I did not express myself well - my How was how does one remove those screws at the ends etc..... since it is not structural what about monel?
The end-screws are not structural in the end-product, but until you have cloth and epoxy wrapped around the "corners", they are. And when you have the lot wrapped around it, you don't want to puncture the layer to get the screws out. It's usually not worth the ekstra work. I guess monel would be an even better choice than bronze, all things considering. I still can't wrap my head around why a professional boatbuilder would use 316 SS somewhere that will mean it'd be starved for oxygen and thus be prone to crevice corrosion. Monel would be perfect in this application, methinks. |
| The only way I can think of removing the "end" screws is to glass the inside first, that leaves the option of removing the end screws and easier to fill and seal from the outside... - just a dumbass throwing ideas around?
If you're interested, Dick Phillips has the first installment on his website: http://www.dickphillips.co.uk/docs/32-36RoxaneW68.pdf I didn't do it quite like that - he's had his frames cnc-cut and whatnot. If I ever build another boat, this will be the way I'll do it, instead of using off-sets from a book, battens and whatnot, lol. |
How deep do you have to go before the water is actually oxygen starved anyway? Some one better tell these guys.... http://www.bosunsupplies.com/product...?product=S3815 |
http://www.binksonline.com.au/store/prod2783.htm (it's a nylon through-hull, if you're wondering). Btw, you may want to read what Bosun Supplies quote Brion Toss for themselves: http://www.bosunsupplies.com/Corrosion.cfm And this (begin half way down): http://www.coletech.net/Resources.htm Most importantly, though, this: http://www2.sandvik.com/sandvik/0140...256B49004451B2 It says much more, but if nothing else, extrapolate from this: Quote:
| Don't worry under epoxy Hello Danish I think you need oxygen or as Meanz says some form of cathodic protection in the water or the oxide layer goes and pitting occurs. Is this a problem under epoxy? I have not had any problems with stainless totally immersed in epoxy as I guess there can be no electron transfer through the totally encapsulating insulator. I don't understand why you have to leave the screws in with strip plank though. Just put some dabs on the inside of the planks to the mould to hold them. If you are worried do the test - put a SS and a Monel screw in a bit of composite and smother in epoxy. Leave in water of a jetty or such for a year or two. Then pull apart. My friend did this a bit and it gave good data on antifouls. cheers Phil Thompson |
Well that's as far as my research has taken me at this point and it explains to me why I have never had trouble where I have used 316 below the water... Anyone for anymore... Nylon through hulls are shocking, talk to any surveyor... Use 304 below deck level and you are going to get trouble. |
| I've been thinking the same issue a bit, but I left them (316) in place. Anyways I made oversized holes and filled with epoxy so they should be totally capsulated and thou protected. If one wants to be more on the safe side with 316 maybe preoxidation could do the trick? I mean thats the real problem here that SS's aren't preoxidized and without oxygen around won't get the protective layer.. |
| Under some circumstances, but please do read the links I have provided you with, instead of just spewing that nonsense. Crevice corrosion is a well-understood factor, and when it comes to such matters, the high contents of chromium works against it in places with crevices where stagnant sea water can sit. Quote:
Oh, you added a bit, Beanz: Quote:
| Is a stainless steel boat possible? | hansp77 | Materials | 91 | 02-09-2011 11:40 PM |
| Stainless Steel Question | dreamer | Sailboats | 10 | 12-07-2009 03:40 PM |
| Stainless Steel Railing | dannie_ga | Fiberglass and Composite Boat Building | 4 | 01-18-2008 12:11 AM |
| Bronze/ Stainless screws | Bremner | Wooden Boat Building and Restoration | 7 | 04-29-2006 08:30 AM |
| Stainless Steel Question | dreamer | Materials | 3 | 05-04-2005 03:25 AM |
