Old 01-16-2008, 12:32 AM
dannie_ga dannie_ga is offline
Rep: 10 Posts: 3
Stainless Steel Railing
I had question, about stainless steel railing, how to make it brighter and closer to the surface of the mirror, what is needed daubing?
Thanks.
Old 01-16-2008, 12:08 PM
Rep: 3125 Posts: 9,399
It needs to be polished, then re-pacified. Try buffing it with stainless polish, then use a conditioner to keep the surface looking nice.
Old 01-17-2008, 05:32 AM
Rep: 756 Posts: 3,328
Between polishings , mix Ospho with a bit of Joy.
The acid will go after any loose iron molecules in the SS surface, the Joy just holds it in place to work.
This is an old trick fixing up Tiawan boats that have mucho SS but were never electropolished.
FF
Old 01-17-2008, 11:00 PM
Rep: 10 Posts: 3
FF
Thank you all!
Taiwan boats that have much SS but were never electropolished, so if it can electropolar, that will be better to look?
I don't now what is Ospho with a bit of Joy, can you explain more detailed?
What's Ospho and conditioner? I'm new for fix SS
Old 01-17-2008, 11:11 PM
Rep: 527 Posts: 792
Sometimes I'm quite sad or even a bit irritable when I mix my Ospho
Will it still work as well as Ospho mixed with joy ?
I'm tired and in a silly mood
Stainless Steel Question dreamer Sailboats 10 12-07-2009 02:40 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 06:40 PM
stainless steel mast? turedogan Sailboats 21 06-05-2006 12:01 PM
Stainless Steel Question dreamer Materials 3 05-04-2005 02:25 AM
Stainless Steel hull? trouty Boat Design 3 11-18-2002 02:57 AM
