Old 05-16-2006, 10:52 PM
searaytuna searaytuna is offline
Rep: 10 Posts: 42
Spraying PVA over Gelcoat?
I have a gelcoat project and have been using surfacing solution on the final coat. Is it better to shoot PVA after final coat? If so, should it be applied while last gel coat layer is relatively wet or tacky? Thanks for any insight.
Old 05-17-2006, 12:06 AM
ondarvr ondarvr is offline
Rep: 226 Posts: 633
It's easier to use the surfacing solution than PVA and for most jobs the results are about the same. If you use PVA, do it when it's still relatively wet, if you wait too long the gel coat will have already tried to crosslink with the air and may not cure as well on the surface. Wax solutions don't always work well in direct sunlight, or on warm surfaces.
Old 05-17-2006, 09:34 PM
Rep: 95 Posts: 462
why dont u use duratec in the gel it will allow the gel to dry hard with out the need for wax or pva it will also level the gelcoat much better with some pratic and a good hvlp gun u can get a peel free gel finsh
Spraying gelcoat Sunfish52981 Fiberglass and Composite Boat Building 1 04-23-2006 09:29 AM
Gelcoat Spraying System for sale BWSeaCat Marketplace 0 01-22-2006 08:46 AM
tips on spraying gelcoat? H2Only Fiberglass and Composite Boat Building 11 12-27-2005 12:39 PM
Equipment for Gelcoat spraying? Johan Linder Fiberglass and Composite Boat Building 3 10-20-2004 10:32 AM
Spraying two color of gelcoat goodwrch Fiberglass and Composite Boat Building 4 05-23-2004 01:42 AM
