Old 01-19-2004, 12:00 AM
Spraying Gelcoat gun types
I have a gravity feed spray gun which I use with spray putty. It has a 2.8 mm fluid nozzle. I was going to try and use it to spray "Gelcoat" but thought I should ask first - will this work. Is there much difference with a spray gun intended for use with gelcoat ???
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
Gelcoat project on 71 Shark LtsGo4ARide Fiberglass and Composite Boat Building 4 07-03-2005 11:02 AM
Equipment for Gelcoat spraying? Johan Linder Fiberglass and Composite Boat Building 3 10-20-2004 10:32 AM
Spraying two color of gelcoat goodwrch Fiberglass and Composite Boat Building 4 05-23-2004 01:42 AM
