Old 05-19-2009, 03:40 PM
jimflorida109 jimflorida109 is offline
Rep: 10 Posts: 4
Spraying awlgrip with 3M full mask with organic vapor cartridge
Hi all,
If I'm going to spray Awlgrip in my backyard homemade spray tent, can I use a 3M full face respirator (6000 series) with an organic vapor cartridge? I plan on spraying with full overall-style suit with hood, gloves, etc. and will change my clothes immediately after exiting.
I know alwgrip says to use an air supply system.
However, according to OSHA if I use an organic vapor cartridge with dust/mist, I should be ok.
http://www.osha.gov/SLTC/isocyanates/mdi/mdi.html
According to OSHA they tested 6001 cartridge and 501 filter and it removed 99% of the isocyanate. So before I head off and kill myself, should I be okay with BRAND new cartridges and filters which I'll discard after more than one hours worth of use?
Old 05-19-2009, 03:56 PM
Rep: 472 Posts: 1,391
I don't know if I would follow my own advice...but it is far healthier and cheaper to pay someone else.
Old 05-19-2009, 04:11 PM
Rep: 527 Posts: 792
Yes, you will be fine with organic vapor cartridges. Search the old posts with the key word: "isocyanates" for a more detailed explanation.
Jimbo
Old 05-19-2009, 09:36 PM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 459
Research
Hey, I did some extensive research and let the numbers sway me.
The name of the tread I posted was " a breath of fresh air ".
NI-OSHA claims that organic respirators can mitigate isocyanate's for a limited time, they were talking hundreds of hours. But since isocyanate's don't have any oder you should change they when you can smell your reducers.
I changed mine after every other coat. (2) per session, since I used the three coat method. It does get expensive but so is awlgrip.
I also have some pics posted in my gallery, you might like my spray tent.
anyway I have those articles and supporting docs on isocyanate's if you want them.
LET THERE BE GLOSS!!!!
Fair winds & calm seas
Old 05-20-2009, 03:06 PM
Rep: 10 Posts: 4
Thanks for the advice guys! I read the thread, and the documents. It's nice to see both research and practical advice come together.
Hopefully the weather lets me get the job done.
Old 05-20-2009, 04:27 PM
Rep: 527 Posts: 792
I have been buying my cartridges at $24 for a box of 10 (5 changes) so even at the very conservative change interval outlined above, this is very cheap compared with buying a supplied air system ( minimum $400).
Grady,
Although iso's do not have a detectable odor, all the products you use with them do. Even the hardeners have detectable chemicals; they are never pure isocyanate. So the paint system has 'warning' properties that make it safe to use charcoal cartridges.
Jimbo
Old 05-20-2009, 10:22 PM
grady's Avatar
Novice
Rep: 70 Posts: 459
Agreed
Yes Jimbo, I agree. What I was trying to say was, if you can smell your product it's time to change your cartridge. And I always was able to change before that happened, even when I was pushing it a little.
Thanks
spraying gelcoat gethookedjr Materials 3 03-07-2007 02:51 PM
Evinrude D.I. 2002 Vapor Separator hmattos Outboards 3 03-01-2007 08:00 PM
a little help spraying gel coat ANGELMAT4 Fiberglass and Composite Boat Building 25 12-16-2006 12:28 PM
Spraying gelcoat Sunfish52981 Fiberglass and Composite Boat Building 1 04-23-2006 09:29 AM
Equipment for Gelcoat spraying? Johan Linder Fiberglass and Composite Boat Building 3 10-20-2004 10:32 AM
