Old 05-20-2005, 10:45 AM
mike Tones mike Tones is offline
Rep: 10 Posts: 3
spray-on truck liner
Hi from the UK. I am about to buy a GRP Yorkshire sailing/fishing coble (18ft). It is basically sound but in need of some renovation. Hull GRP is in sound condition but unfortunately has been painted. Do I repaint, remove to gel coat or as someone suggested spray over a film of spray-on truck bed liner - urethane polymer coating containing kevlar, as a tough, long lasting and flexible protection?
Regards - Mike
Old 05-20-2005, 01:42 PM
Rep: 1623 Posts: 1,483
Depends on what type of finish YOU want. Workboat finish...remove loose paint, scuff, repaint. Moderate finish...remove loose paint, fill and feather, prep sand, repaint. Etc, Etc... The applications I've seen of spray on urethane have not been good in the marine environment, mostly due to lack of "tooth" or adheasion that prevents the covering from lifting in big steets after it is damaged. If you have to put more work into the surface prep as paint, the advantage of using it is lost, especally on exterior surfaces.
Old 05-20-2005, 02:01 PM
Rep: 10 Posts: 3
Many thanks and I understand where your coming from. The demo truck liner I looked at I took a screwdriver to and couldn't even mark it.
Old 05-21-2005, 11:39 AM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
Polyurethane paints are excellent for the marine environment. I've sprayed several boats that are holding up very well, even when trailered.
No amount of surface prep work can compare to the huge job it is to re gelcoat a boat. I charge around $1200.00 to paint an 18 foot boat, $10,000 to gelcoat it. (in other words, I don't re-gelcoat boats, it's cheaper to buy a new hull!) Good sanding and prep will make a urethane paint job last 10 years.
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 05-22-2005, 08:42 AM
Rep: 10 Posts: 3
many thanks - does this mean that the rather thick, slightly rubbery, truck bed liner kevlar/urethane spray is not suitable?
Old 05-22-2005, 11:57 AM
I agree with Chris that hard Polyurethane paints will last many years. But as I said before, I've had poor performance from the soft urethane coatings that are thick and rubbery. Big problem is that it thins due to surface tension at outside corners which quickly wear through. Once it is opened, it quickly sloughs off. Just my experience...
Old 05-22-2005, 03:37 PM
Hopeless Boataholic
Rep: 173 Posts: 604
Probably not, they're not designed for marine use. Maybe good for the cockpit.
Craig Cavanaugh
Old 07-03-2005, 04:29 AM
Busted Knuckle Busted Knuckle is offline
Rep: 15 Posts: 9
http://www.sanitred.com
Old 07-03-2005, 06:02 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Knuckle,
Interesting product, might come in handy someday, thanks.
Yokebutt.
Old 07-03-2005, 08:20 AM
Rep: 15 Posts: 9
I am in the process of rebuilding the floor in a 27' Century Raven. I came across this product about a year ago from someone on this board. I am going to give it a try, I will post the results.
I am going to try and use it directly over the plywood without fiberglassing the deck. I am also going to use it for a fish locker below the deck, hopefully it will work, looks promising.
Liner matthewd Fiberglass and Composite Boat Building 1 09-22-2005 10:28 PM
Fiberglass Hull Liner Question Seadog Fiberglass and Composite Boat Building 7 08-14-2005 07:42 PM
Spray painting tips Phil Thompson Fiberglass and Composite Boat Building 1 02-07-2005 12:24 AM
spray rails Hannu Rantala Boat Design 6 12-19-2004 01:25 AM
Spray rail design nevd Boat Design 9 05-06-2004 07:50 PM
