Old 11-07-2004, 07:58 AM
David Cowen David Cowen is offline
desperock
Rep: 10 Posts: 24
Spray Layup Repair
I am patching up some holes in my hull project but it seems to be a spray layup with a chopper gun. There are no defiined layers in the laminate that I can see apart from the gel coat. What is the recommended hand layup technique for this type of hull?
Old 11-19-2004, 08:33 AM
Rep: 48 Posts: 638
David,
i) Cut back damaged area to sound laminate
ii) Grind back the edges to a feather bevel (either single or double)
iii) Surrounding of the repair area to be cleaned, degreased and dried
iv) Fix and secure temporary backing panel over the hole (with release agent!!!)
v) Depending on which side you're working, apply a gelcoat resin untill touch dry
vi) Apply the layers of reinforcements untill the hole is flush, for a spray-up laminate I believe it's best to use CSM, resin can be either poly or epoxy, epoxy is better/more expensive
vii) Last layer(s) to extend well over the edges of repair area
In case of large repair, increase thickness with about 25% and add overlaminated 50x50 mm battens on the edges of the repair.
Good luck
Dutch Peter
Old 11-19-2004, 08:13 PM
tja tja is offline
Rep: 11 Posts: 125
tja
Weather it's sprayup or hand layup there is little difference. The important thing is to prepare the surface properly by grinding the afected area and hand layup the damaged areas with a General purpose polyester resin. That is what the boat is made of so I would use the same type resin. Taper in the layers. Don't make a fairly easy job dificult, keep it simple, Tom.
Old 01-11-2005, 02:36 AM
gulfcoast crabb gulfcoast crabb is offline
Rep: 10 Posts: 10
tja is right its simple keep it that way, grind the affected area back to good clean glass beveled away from the hole,make sure the area is clean and dry before you start the repair, wipe it down with acetone or another solvent. for a small area i would just use poylester resin and chop, the chop can be torn apart and used as a filler, build it up above the original layer of glass, then sand it down as neded.
Old 01-11-2005, 10:21 PM
Aaron23 Aaron23 is offline
Rep: 10 Posts: 5
Epoxy Layup over Polyester Gelcoat
Dutch Peter, you mentioned using epoxy resin for the repair over partially cured polyester gelcoat.
Is this ok to do? I'm constantly told that gelcoating a repair made with epoxy is a no-no, but will it work if done in the reverse order (I understand the bond will be mechanical)?
I am repairing 2" x 10" hole at the very bottom of the boat and I want to repair it from the outside in with epoxy using a mold as you mentioned, but I want the outside surface to be gelcoat.
Will this work? Any Suggestions?
I'm attaching a pictures of the hole prepped for the repair, maybe this will help the originator of this thread - anyone want to critique my work so far?
Old 01-13-2005, 09:21 AM
Rep: 48 Posts: 638
Where did I say that?!
I understand that epoxy is bonding much better to poly than poly to poly. Poly to epoxy is the worst bonding.
Why not replace the gelcoat with epoxy filler at the repaired area, that why you have the smooth hull and no bonding problems!!
Dutch Peter
Old 01-17-2005, 10:56 AM
Rep: 10 Posts: 5
Can anyone recommend a specific epoxy product that I could use here?
Old 01-18-2005, 06:38 AM
Rep: 48 Posts: 638
Aaron,
As you are living in the US, try West Systems
Dutch Peter
hull repair eurotk1 Fiberglass and Composite Boat Building 13 04-17-2005 11:53 PM
Spray painting tips Phil Thompson Fiberglass and Composite Boat Building 1 02-07-2005 12:24 AM
Fiberglass repair tprocurt Fiberglass and Composite Boat Building 2 11-09-2004 05:01 PM
Structural Repair of Fiberglass Hull Randytea Fiberglass and Composite Boat Building 8 10-07-2004 06:32 PM
Spray rail design nevd Boat Design 9 05-06-2004 07:50 PM
