Old 04-22-2008, 04:53 PM
Sam III Sam III is offline
Rep: 46 Posts: 71
Split mold for hull
I am working on the design of a center line split mold for a sail boat.
Mold will have normal flange on the centerline.
How do you build the 'seam/joint' so that a large parting line of gel coat does not build up when you spray it in?
Thanks
Sam
Old 04-22-2008, 07:58 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
No big deal, but you do normally get a line from the split, it is however a built up line so it is easy to just sand off. If you made the mould very carefully the sand off line would of course be smaller, but in reality it simply just does not matter.
Sometimes we put tape over the seam line, but for a hull, we just sand it off.
Old 04-22-2008, 09:13 PM
ratrace2's Avatar
ratrace2 ratrace2 is offline
Rep: 84 Posts: 542
Thanks
Sam
Fill it in with modeling clay, chavant, or something like that.....just firm enough and non-reactive to mold-release and Gel....
Who Said That?.....................
Old 04-27-2008, 10:28 AM
Rep: 46 Posts: 71
Any suggestions for 'parting board'? Thinking of using particle board and putting a couple of coats of primer on it before release agent.
Thoughts?
Old 04-27-2008, 10:39 AM
ratrace2's Avatar
Rep: 84 Posts: 542
Thoughts?
Sam,
na, that will never work, too rough. It, the resin, will just pull it apart.
Only if you wrapped 6Mil poly around plywood could you use it as a parting plane. You have to have a smooth, non-pourous surface. Something like metal tape, like they use to repair trucks, with the sticky tar on one side and the aluminium, thick, foil on the other..If you coulg get some plexyglass that would work and spray it with PVA, Mold release.
Old 04-27-2008, 11:01 AM
Rep: 46 Posts: 71
What about 'Melamine faced' board?
Sam
Old 04-27-2008, 11:16 AM
ratrace2's Avatar
Rep: 84 Posts: 542
Sam
Sam,
Sure, just test a little first. Use a good smooth coat of PVA sprayed on it.
Remember, test, test, test everything a little bit.
Old 04-27-2008, 11:30 AM
ratrace2's Avatar
Rep: 84 Posts: 542
I think there is a better way:
Listen, build your plug and then glass it. OK, now you have your mold.
Now, build up a flange from bow to stern, then cut the mold in half.
The kerf of a sawzall is approx. 1/16th inch. No one will notice the size reduction in your boat. Or, just put a formica shim between the mold haves to restore the dimensions.
_________________________________________________
THE FLANGE: I like to use hardwood like Rock maple, or oak. Make the flange approx 4 inches high and about 2 inches wide. Drill holes through your flange 1/4" dia. every 12 inches should do it.
Old 04-27-2008, 01:14 PM
juiceclark juiceclark is offline
Previous Member
Rep: 71 Posts: 373
We're using the back, very smooth side of vinyl siding. You can buy it for nothing at Home Depot or Lowes and nothing sticks to it...especially with quick release on it.
I'll try to find a pic or two of how we did it for our 50'.
Tony in Sw FL
Old 04-27-2008, 02:08 PM
ratrace2's Avatar
Rep: 84 Posts: 542
Tony in Sw FL
Juice,
where did you find that vinyl siding? Years ago, I looked all over HD for the same applications, couldn't find "that".
Need "Pics'....bad.
Old 04-27-2008, 04:23 PM
Rep: 46 Posts: 71
Tony in Sw FL
I was also thinking about the smooth finished 4' x 8' Thrifty White Tileboard
Model 346428
SKU 346428
http://contractorservices.homedepot....c-7147640e84bb
from Home Depot as well. As it is only 1/8" hardboard was planning to glue to 1/4" luan ply for some stiffness.
Sam
Old 04-27-2008, 04:35 PM
ratrace2's Avatar
Rep: 84 Posts: 542
Model 346428
SKU 346428
Sam
Well, if that is the case, why don't you just use some "flashing" and 3M it to the Luan....
Old 04-27-2008, 05:22 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Sam, I use melamine faced particle board succeessfully- attach to brackets of same using "hot melt" glue - it shaves off with razor blade easily later. Regards from Jeff.
Old 04-27-2008, 08:09 PM
Previous Member
Rep: 71 Posts: 373
I was out at the mold today. They have it split in two because they're polishing the tooling gel on the mold. So, the little piece in the middle was removed and I forgot to ask exactly what it was and where they got it. I'm pretty sure it was from Lowes and was a piece of flat, white and smooth vinyl(very thin)...could be flashing but looked like siding without the flange along the edge. I'll ask tomorrow and give you an update.
Old 04-27-2008, 08:29 PM
ratrace2's Avatar
Rep: 84 Posts: 542
Juice,
Problem, I think this guy is working with a plug, not a "female" mold. Sure, you just slam the mold halves shut against the "vinyl siding/parting plane".
Maybe we should find out what this guy is working with???
_________SamIII, Question:______________________
are you working with a plug....what kind of "stuff" are you doing. Care to lay some "context", background for your efforts?
Building a hull mold, has anyone done this??? gbaaron Boat Design 19 09-28-2006 07:13 AM
Building a hull mold??? gbaaron Powerboats 3 09-27-2006 11:25 AM
using existing hull as mold? Rippin Lips Boat Molds 25 02-22-2006 04:36 PM
Pacemaker Hull split leokow Fiberglass and Composite Boat Building 5 11-20-2004 05:00 AM
Hull Building-up on mold fbeaudoin Fiberglass and Composite Boat Building 3 10-30-2004 09:17 AM
