| Split line touch up! Guys, I need some advice on a possible touch up. The deal is that I'm using polyurethane paint instead of gelcoat and after demolding there might be a few areas that might need a touch up. Now I know the two halves of the mould I've made butt up very well but as the product won't be painted after release I would like some input from the experts. The product is a fishing ski and I'm using epoxy. When I remove the flash line can I then polish the area as one would with gel coat? What's the deal on spraying more urethane over the affected area? Thanks all. |
| OK, let;s see if I understand correctly: You have a (perfect) mould with a split line. You spray in PU paint, then epoxy laminate. Right? After demoulding, clean up the split, lightly sand, and touch up the sanded area with some new paint. Then polish the complete product to remove overspray and feather the repair into the original paint. Should be doable...
| Thanks Herman. I kinda figured that was the way to do it. Now I know for sure. This is my first boat (fishing ski) and although I've been around high performance composites since the 80's I've never really been into large scale production. Trying to keep the finishing to a minimum. |
| Split Mainsail. Has this been tried before? | Omeron | Sailboats | 21 | 11-18-2007 10:27 AM |
| touch cad and 3d digitizers | Bartsher@aol.co | Software | 1 | 01-11-2007 03:57 AM |
| split down the keel | MDP | Fiberglass and Composite Boat Building | 9 | 09-15-2006 05:05 PM |
| Aluminium; finishing touch | winters | Boatbuilding | 2 | 09-14-2006 08:00 PM |
| How to/best way to touch up urethane paint runs…? | paularey | Fiberglass and Composite Boat Building | 6 | 11-28-2005 04:50 PM |
