| Spider cracks - it can NOT be good - what to do On cleaning the inside of the hull and removing years of dirt - I noticed spider cracks in the fiberglass of the transom --- I assume that this is NOT a good thing but do not know what it really means or what I should be doing about it. There is not many and they are not big - but I am sure that left alone - it will only get worse. Cleaning the outside of the transom - there appear so be a few very thin spider cracks as well. The transom appears to be solid otherwise. Comments and help would be appreciated. Thank you Last edited by MDCHILDS : 09-19-2011 at 11:51 AM. Reason: missed an important word |
| Spider cracks are from impact normally or in some cases where a Bracing panel sandwiched between the layers of glass has had to much load at some time and the weakest point is the end of the braced part . Cracks inside impact out side ,cracks outside pressure and stress from inside !! Transom's you can just about stake your life it will be wet !! If its a older boat there will be holes where things have been mounted at some time that may not have been filled properly and leaked . The hull drain may also not have had the holes sealed properly and water gets in to the plywood packer . Screw holes are the favorite place with a finger wipe of silicone or something , never works !. The motor hanging on the back will possible be twice what was origanally there and the transom was never meant to have that kind of power so stressed !! we keep exspecting more and never adding to the strenght so somethings got to give some where . ![]()
| need help - 1978 Thompson 18 spider cracks - gelcoat or paint | boater1 | Fiberglass and Composite Boat Building | 9 | 09-13-2011 10:51 PM |
| spider web cracks - now with photos! | marekpavel | Boat Design | 3 | 10-13-2007 10:24 AM |
| That spider boat is called the "Proteus" | kach22i | Boat Design | 20 | 01-26-2007 03:41 PM |
| spider Cracks? | H20fwler | Fiberglass and Composite Boat Building | 17 | 01-16-2006 04:27 PM |
| Fiberglass "spider" crack repair | James MM | Fiberglass and Composite Boat Building | 3 | 07-27-2004 08:38 PM |
