Old 07-13-2011, 02:39 AM
wiremucox wiremucox is offline
Rep: 10 Posts: 3
small wheelhouse construction
hi i have a 6 metre sail boat thats been converted to a motor boat. sails and mast removed keel gone too. i want to make a small wheelhouse where i steer from. will use plywood and fibre glass i think. any ideas suggestions would be welcome. il try and add a photo?
Old 07-13-2011, 07:02 AM
Rep: 1493 Posts: 7,447
Have you had the boat in the water? With the ballast removed, adding more weight on top is not a good idea.
Old 07-13-2011, 07:32 PM
Rep: 10 Posts: 3
yes had the boat in the water and seems to handle well , was only going to add a small lightweight wheel house, maybe out of ply and glassed over. how do i add photos to my questions? thanks bill
Old 07-13-2011, 07:47 PM
Boat Design Net Moderator Boat Design Net Moderator is offline
Moderator
Rep: 647 Posts: 184
Click "Go Advanced" on the quick reply or start your reply with the larger blue post reply button. Then click "manage attachments" and select the jpg files to upload from your computer. http://www.boatdesign.net/forums/faq...chment_explain
Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules
Old 07-13-2011, 09:16 PM
Rep: 3125 Posts: 9,399
A small wheelhouse will be fine, assuming the boat currently sits level on her lines. The removal of the rig shouldn't affect her weight much, but the keel might. What did the keel weigh approximately? If it was less then a few hundred pounds (130 kilo), they don't worry about it.
1/4" (6 mm) plywood will work wonderfully for your doghouse. It can be covered in a light weight cloth, say anything between 2 and 10 ounces will do. The cloth just water proofs and adds abrasion resistance, but no significant strength. Use 1x2's (20 x 40 mm) or 2x2's (40 x 40 mm) "studs" in the walls and roof beams. Keep things light as Gonzo points out; you don't want much weight up high or it can upset the stability curve a great deal.
Old 07-13-2011, 09:24 PM
Rep: 10 Posts: 3
thanks have uploaded a photo somewhere!
Wheelhouse windows Johns1152 Boatbuilding 79 01-28-2011 12:08 PM
Novice Looking for Advice on Small Wooden Boat Construction oberhelr Wooden Boat Building and Restoration 6 03-15-2009 10:19 AM
one-off mold/plug construction for small-parts westsail42 Fiberglass and Composite Boat Building 6 09-21-2006 08:13 AM
Educational resources for design/construction of small fiberglass boats? Splint Education 4 02-09-2006 08:35 AM
Wheelhouse pengreg Sailboats 6 03-14-2005 01:33 PM
