#46
| Number one never lay up over oil based paint !!ALWAYS USE A 2 POT URETHANE . Number two The minimum draw is 1.5 degrees on all surfaces !!! number three Radius need to be as big as is possible to suit the item you are making ! 4 mm to 10mm radius Dont forget when you make a plug make it so you can dismantle it piece by piece from inside the mould not tear the mould apart . ![]() If you have a intricate part the spray a coat of watered down PVA first then was over the top . When you put pva on you can not build up coats just thickness !! And thats the complete opossite to how you should be using PVA . The spray should be so fine that if you can see it on the mould you have to much . I always thin the pva with water about 60% and spray very very very fine . if done properly you dont even need any wax at all !! |
| Creating a mold from an existing part | Dynafoiler | Fiberglass and Composite Boat Building | 7 | 07-11-2009 09:13 PM |
| Advice on making a small moulded part | alyne | Materials | 10 | 10-16-2007 01:53 AM |
| Stuck part on 2nd pull | Phil Locker | Fiberglass and Composite Boat Building | 2 | 10-03-2007 08:05 AM |
| Blocking off part of mold | Roly | Fiberglass and Composite Boat Building | 3 | 02-18-2007 09:33 PM |
| Part stuck in mold!! Yikes!! | searaytuna | Fiberglass and Composite Boat Building | 5 | 03-09-2006 03:40 PM |
