Old 07-22-2007, 09:18 PM
cassanova cassanova is offline
Rep: 10 Posts: 3
Small hole in floor
Hello everyone. I have a question for you. Yesterday i was pulling up the teak strips that hold the gas tank in place(previous boat owner must have done this) because im going to carpet my boat. I noticed that the hole from the screw closest to the wall went all the way through the boat. If it helps it is a 69 model tri-hull. what would be the best way to plug this hole? Fiberglass?? Thanks in advance.
Old 07-22-2007, 10:48 PM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,314
Fill it with micro ballons or another marine type filler and glass over it on both sides.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 07-22-2007, 11:11 PM
Rep: 505 Posts: 1,658
for temporary fix ,,jam a pease of wood in it ,,like a small dow,,then when you pull the boat ,do the latter
Old 07-23-2007, 01:18 AM
Rep: 2891 Posts: 8,792
I'd recommend you not use a light weight filler like micro balloons, which have no strength. Milled fibers, silica, cab-o-sil, wood flour etc. would be much better choices. The light weight fillers are to fair (make smooth) uneven surfaces, not fill holes. Log onto www.westsystem.com and look up fillers in their how to section. Or you could buy a premade filler in a tube sort of thing at the local marine parts store.
Old 07-23-2007, 04:16 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
If its just a screw hole, ie approx 1/8 I would put 3/16 drill into it but not all the way through . This would clean out the hole ready for a good adhesion. I would mix up some epoxy and whack it in the hole, push it well in , when it come out of the hull wipe it off and put some tape on it. Put some tape on the inside too.
Then all you have to do is carefully clean off the outside just before it hardens fully with a razor blade.
Old 07-23-2007, 01:06 PM
mtnrat mtnrat is offline
Rep: 10 Posts: 53
Marine-tex
http://www.marinetex.com/PRODUCT%20P...rod%20info.htm
Old 07-23-2007, 01:22 PM
SamSam SamSam is online now
Rep: 455 Posts: 1,606
If the hole only goes through the deck/floor, you only have to squirt in some caulk to keep the water out of the plywood. If it actually goes through the hull to the outside of the hull, repair as above.
Old 07-27-2007, 09:14 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
dont ever fiberglass over filler, it will crack, take a 4 inch grinder and feather out the hole,( dont make it a circle, circles that have been patched show up on final paint job) and fill with glass,and the grinding job doesnt have to be the whole 4 inch grinder, gouge it , making a small line with edge of grinder then feather that out
Fiberglass hole!?! northwoodspaddl Fiberglass and Composite Boat Building 7 05-04-2006 09:34 AM
Hole in boat. gwaa98 Fiberglass and Composite Boat Building 10 02-02-2006 04:48 PM
Help with hole in boat! gwaa98 Boatbuilding 2 01-30-2006 04:24 PM
Hole 01pinkfloyd Boat Design 2 05-08-2004 07:16 PM
Hole In My Boat antonblack Wooden Boat Building and Restoration 3 04-21-2004 04:50 AM
