Old 08-23-2008, 11:06 PM
pasty63 pasty63 is offline
Rep: 10 Posts: 44
slight perforation of the hull
While digging out some rotten bulkhead material, I stuffed the end of my sawzall blade through the bottom of the hull . The cut is about 3/4" long and 3/32" wide. I'm planning to fix it about the same as a blister - any pointers?
Thanks - .b
Old 08-24-2008, 09:32 PM
ondarvr ondarvr is offline
Rep: 226 Posts: 636
It's not a big deal. It sounds like you'll be doing some glass work on the inside of the boat, so just cover it from the inside when doing that work.
If you know how to repair a blister, then do it that way on the outside and it'll be repaired with no future issues.
Old 08-25-2008, 10:54 AM
mongo75's Avatar
mongo75 mongo75 is offline
Rep: 95 Posts: 262
Just grind a bevel on both side with at least a 1/4" opening along the cut line (to allow the epoxy to touch) and then just glass it closed. For the bottom, you can prefab the patch on some plastic wrap or wax paper and once soaked with epoxy just slap it on and tape it tight to the hull, or even wedge it up with a block to keep it from drooping.
Danny
Old 08-25-2008, 11:10 AM
Rep: 10 Posts: 44
slight hull perforation
What makes this perforation more interesting than some , is that it is less than 1/2" from the bottom of an engine stringer - and slightly to port. From the inside, its in a 4" by 1/2" slot created by rotting plywood that forms part of the engine room bulk head - and separates the engine stringers from the longitudinal 2x6's running forward. I can get to it from the top as long as I'm reaching with something > 4" long and < 1/2" wide - but I think effecting the patch from outside will be easier.
Thanks for the input - this is a fun site.
Old 08-25-2008, 11:12 AM
mongo75's Avatar
Rep: 95 Posts: 262
As long as you use epoxy, you'll be fine. Just but a good bevel on the outside and it'll hold great, the inside would just be to kinda lock the patch in place.
Danny
Engine stall on slight acceleration mahall665 Sterndrives 2 03-09-2008 03:57 PM
Hull finish on high speed hull. Polished or Matt? Sooty Boat Design 2 02-03-2008 01:08 PM
differences between nitro hull and vee pad hull riveramunizaga Boat Design 4 05-24-2005 11:27 PM
what is faster a flat boat hull or a vee pad hull riveramunizaga Boat Design 24 05-24-2005 03:18 PM
Hull or hull & deck broke apart during 40-50 mph turn Jeff Powerboats 1 07-09-2002 01:27 AM
