| skin coat csm material I have built a good many frp parts, I was told to use 3/4 oz.csm now building a 23' power boat I have heard of useing 2oz csm for the first skin coat is the 2oz material comon for such a hull? all using polyester material Thanks |
The light glass is not the complete answer to this potentual problem !!. ![]() |
| Have you built your parts using csm only? |
| ok yes its possible to build boats useing just chopped strand matt , its what we did 30 or more years ago when fuel was cheap and not to many owners cared how hevy there boats were , The biggest boats i have worked on using just csm were 42 ft long now wovens or stitched matts anywhere in the total construction of this companies boats . The thin glass in the first layer is for osmosis protection ! it needs to be resin rich and well rolled out so there are no microscopic bubbles any where. !!! Thats ok but you need to use P matt not E matt ! P matt binder is less likely to absorb moisture !! Also the first 2 layers should use Vinylester resins which is the third step to osmsosis protection ! this is old knowledge !! ![]() |
| Of course tunnels it is possible, I know. If it´s sensible is another question. We all remember the chopper guns (some are still in use). >>>The thin glass in the first layer is for osmosis protection<<< and to avoid print through, we should add.. Regards Richard |
| let me refine my question in the past I have used a light csm skin coat prior to other scheduled laminates, now with this boat, my question is would the 2 oz csm be better by being bulkyer then the 3/4oz csm I also understand the resin should be catylisted a bit hotter then subsequent laminated in order to minimize the resin' styrene attack on the gel coat, |
| 3/4 oz is thin for a skin coat, 2 oz would be better for what a skin coat is designed to do. 1. Allow easy air removal. 2. Help prevent print through. 3. Help prevent blistering, by using a more expensive, higher quality resin. One 3/4 oz won't do any of these very well, the layer will be too thin. On small detailed molds multiple layers of 3/4 may be used if heavier mat won't follow the contours. Many times you end up with more print through and more of a chance of blisters when using a very thin skin coat, not just because the layer is thin, but because it is frequently under cured. There isn't enough resin to generate much energy for a good exotherm, resulting in poor cross linking. |
| Top Coat Material for serial production with epoxy and female mould | emresandan | Fiberglass and Composite Boat Building | 4 | 08-04-2008 01:45 PM |
| CSM Veil | Bullseye | Fiberglass and Composite Boat Building | 4 | 10-18-2006 07:11 PM |
| CSM/WR vs Stitched Bx/Qx | MattStudent | Fiberglass and Composite Boat Building | 2 | 04-20-2006 10:50 AM |
| LAMINATION SCHEDULE - skin coat | brad123 | Fiberglass and Composite Boat Building | 7 | 06-01-2004 01:04 AM |
| gelcoat/skin coat lamination issues | goodwrch | Fiberglass and Composite Boat Building | 11 | 03-07-2004 12:18 AM |
