Old 04-19-2005, 09:51 AM
sfsailing sfsailing is offline
Rep: 10 Posts: 3
site glass installation
Anyone out there have experience/advice about installing a site glass for viewing the rudder and keel? What type of material would be used? Lexan or laminated safty glass?
Thanks
Old 04-21-2005, 12:13 AM
Rep: 10 Posts: 3
I take it no one has ever put a site glass into see if kelp or other bad thing have stuck on the keel or rudder.
Old 04-21-2005, 02:29 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Now, this is going to be a bit embarrassing, but installing a sight glass is one of the few things I've never done on a boat. I was hoping that somebody with first-hand experience would give you exhaustive directions, but, if that's not going to happen, my first inclination would be to recommend a lexan window installed with 3M 5200, but as I said, don't actually have any first-hand experience myself.
Yokebutt.
Old 04-21-2005, 04:03 PM
wet feet wet feet is offline
Rep: 120 Posts: 292
I worked on a boat which had such a window to view the prop so that the crew could be sure it was folded while racing. The recess had been moulded in by adding a disc to the surface of the hull mould and a piece of 6mm poycarbonate about 70mm diameter was bedded on butyl rubber mastic.The end result was never mentioned so on the basis that no news is good news it was judged to be a success.
Old 04-22-2005, 11:15 AM
Rep: 10 Posts: 3
Thanks wet feet, it is a place to start. Some how I think I will need to screw or bolt the plate in to give me a more secure feeling that it will not just pop out. I am just afraid to screwing or bolting unless doen very carefully will crack the lexan or plastic.
Old 04-23-2005, 03:27 PM
Rep: 120 Posts: 292
The panel I mentioned in my earlier post was retained by three small bolts.My only reservation is that polycarbonate moves around quite a lot with temperature changes and the bolts may crack it,something I have seen with polycarbonate cabin windows.In use,there is only the force of gravity to resist and that is opposed by the water pressure on the outside of the hull.Good luck with the project.
Old 04-24-2005, 11:11 AM
Rep: 466 Posts: 640
Start Here
http://www.diveweb.com/commdive/features/pvho.html
http://www.normas.com/ASME/pages/PVHO.html
http://www.psubs.org/designguide/wwindow.html
Good luck
carbon glass balsa core rturbett Fiberglass and Composite Boat Building 8 08-31-2005 12:18 PM
epoxy and glass inside and outside? and more Nordson1960 Wooden Boat Building and Restoration 6 05-22-2005 09:26 PM
Glass over good plywood hull? Ed Hoban Wooden Boat Building and Restoration 10 02-11-2005 01:26 AM
Glass Bottom Boats Arrowmarine Boat Design 6 08-20-2004 03:27 AM
UK - Fibre Glass Workers Required MnM Int. Services & Employment 1 07-07-2004 10:42 AM
