Old 08-31-2010, 03:00 PM
John Hanafin John Hanafin is offline
Plastic Deck hand
Rep: 10 Posts: 14
Silly mistake!
Just thought id share a recent balls up with you.
We had a hole in our transom due to a collision with a submerged car, so we lifted the boat and today grinded it all back made the hole ready to repair, filled with ply wood and resin. Little did I know that the local resin ( im in Nigeria) is not pre accelerated. And we only have two days in the dry dock, so now we begging for more time to lay up before we can continue with the repair. Oh well live and learn!
Old 08-31-2010, 07:08 PM
larry larisky larry larisky is offline
Previous Member
Rep: 0 Posts: 0
this is my philosophy.
don't explain, don't complain
Old 08-31-2010, 07:52 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Thanks for explaining your philosophy, Larry.
Old 09-02-2010, 01:46 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Best is to take it off, and redo the repair. It might even be the fastest solution.
And yes, that sucks.
Old 09-06-2010, 02:41 AM
zerogara's Avatar
zerogara zerogara is offline
build it and sail it
Rep: 64 Posts: 142
I think the reason they do this is because in high temp environments resin lasts longer that way, otherwise it tends to turn to molasses.
Every time you get a new batch of chemicals it is best to use a small quanity for a test. I once had bad catalyst sold to me and it took a while to figure it out till I used some of my old left over catalyst.
"People demand freedom of speech to make up for the freedom of thought which they avoid."
Soren Aabye Kierkegaard (1813-1855)
Old 09-06-2010, 09:58 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
And keep the accelerator ,when it arrives, stored well away from the mekp.
Very Silly Question Woodser Boatbuilding 19 03-06-2007 08:21 PM
Help for big mistake with epoxy jfblouin Materials 4 06-10-2006 05:01 PM
silly question ? fcfc Propulsion 1 09-16-2004 09:47 AM
a silly question ...? Lew Morris Sailboats 5 04-28-2004 08:09 AM
a silly question...? Re: CO2 Lew Morris Boat Design 1 04-13-2004 07:56 PM
