  #31
Old 11-02-2009, 05:58 PM
mozart mozart is offline
Rep: 10 Posts: 7
pics
Have a lot of pics but you would need to tell me how to send them, born in 1756, I am not that good with computers.
  #32
Old 11-03-2009, 08:48 PM
Sam III Sam III is offline
Rep: 18 Posts: 65
Originally Posted by Submarine Tom View Post
Sam III & mozart (two birds with one stone on this thread),
I am most interested in pictures of your projects.
How about it?
Tom
Tom,
Go to http://www.thirdcoastcomposites.com/...mine/index.php for project photo's.
Sam
__________________________________________
We build Mini's www.thirdcoastcomposites.com
  #33
Old 11-04-2009, 12:08 AM
Submarine Tom Submarine Tom is online now
Mariner
Rep: 127 Posts: 330
mozart,
I hear 'ya. I was born 200 years before you, I can't make it happen either.
SamIII,
You're going to have to be a little more specific as there are 100's, perhaps
thousands of photos there.
Tom
  #34
Old 11-04-2009, 01:20 AM
mark775 mark775 is offline
Rep: 141 Posts: 383
You're already going traditional, good, but another factor in why it is better is that lead absorbs some grounding or container shock and hard and fast things transmit it. Perhaps one of the guys that knows how much harder antimony/lead alloy is can tell me if we lose the "container cushion" of soft lead by the addition of too much antimony.
  #35
Old 11-04-2009, 05:12 AM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 592 Posts: 2,800
About 3% Mark.
And the lead does not get so hard that the main properties are lost. (but noticeable harder)
For a "home made pour" you need to make a pre pour alloy. Use 28% antimon in 10% of the total amount of lead, let it cool down, cut according to the fractions of material you melt in one go.
Regards
Richard
Fortior est qui se quam qui fortissima vincit Moenia.
  #36
Old 11-04-2009, 10:42 AM
Rep: 18 Posts: 65
Tom,
I looked and there are very few pictures of the lead bulb,
http://www.thirdcoastcomposites.com/...album=8&page=7
and the next page.
I guess I was to busy with the pour to take pictures.
Sam
  #37
Old 11-04-2009, 12:43 PM
Fanie Fanie is offline
Fanie
Rep: 893 Posts: 3,228
Wow ! You went to a lot of troubles for a mould there. I was just thinking, if you make a former and use paper pulp to make a mould to pour in, won't it be cheaper and easier ? You can make the mould four parts and seal the paper with silicone on flanges.
The mounting flange to the boat looks a bit narrow to me. If you are hit by a wave side on I can see you can run into troubles there.
Regards
Fanie
  #38
Old 11-05-2009, 02:51 PM
Rep: 10 Posts: 7
painting a lead keel? or other treatment
My 6 foot long 2" wide 7" high lead keel came from the foundry.
Looks great mut seface rough due to the glasswater treatment.
What would be a good way to treat the surface before mounting/attaching the keel under the boat?
  #39
Old 11-05-2009, 04:05 PM
Mariner
Rep: 127 Posts: 330
SamIII,
Nice pics, thanks. Great job on the bulb, I hope it stays on!!!!
Tom
  #40
Old 11-05-2009, 04:17 PM
Rep: 494 Posts: 3,842
Use a planer. It is the easiest and fastest way to remove lead. You can also pound on it with a big hammer.
  #41
Old 11-05-2009, 04:34 PM
Rep: 10 Posts: 7
painting lead keel
Ok fine, do you meen an electric one?
Why not put some putty or glass fibre on the surface to avoid hard job?
  #42
Old 11-05-2009, 06:25 PM
If you have voids, fill them with epoxy. However, you can use an electric planer to take down the bumps, specially on the top. Hammering also works well
  #43
Old 11-07-2009, 07:09 PM
Rep: 18 Posts: 65
SamIII,
Tom
Tom,
It has stayed on with no problems. It has taken one serious grounding that lasted 6 hours in the mild waves and hit a rock with only minor damage to the leading edge of the glass shell on the keel. We have removed some keel bolts after the major grounding and there was no damage to the structure in the bottom of the boat or to the keel bolts themselves.
With a 200 mm x 660 mm flange on the top of the keel the 12 x 12 mm keel bolts will keep it in place.
Plus we used the designer's design and he has had several hundred's of his boats successfully built and sailed in the Mini Transat, 4200 miles offshore.
Sam
  #44
Old 11-07-2009, 08:29 PM
Mariner
Rep: 127 Posts: 330
Sam,
Good to hear. Sleep well.
Tom
Pc and CLR vs CP lead... Sean Herron Boat Design 5 02-02-2008 09:33 PM
Lead Bulb matalag Boatbuilding 7 06-26-2006 12:10 PM
lead in aluminium ted655 Sailboats 12 09-06-2005 08:24 PM
Casting lead vabob7 Boat Design 0 03-08-2005 11:32 PM
Schooner Lead Bob A. Boat Design 11 01-23-2004 09:56 PM
